Results 1 to 11 of 11
Thread: OK - Here's what I got...
    Jul 2014
    So Cal
    3
    Hey All - I've been reading this forum since I built and opened my pool last year. I've been following the tips listed on this website (Thank you by the way), but I'm obviously doing something wrong and figured it was time to register and get involved...
    I have an approx. 22,000 pebble pool with a SWG. Last summer was great as all my home testing came back good and the pool water was clear and looking good. This summer season things have changed. My Chlorine levels have been consistently low and I seem to have the start of a long, rewarding relationship with algae. Today I brushed the pool and it looked as if I was brushing green dirt off the walls. So I took a water sample into my local big named pool supply house and had my pool water tested. Here are their results:
    FC 1
    TC 2
    Salt 3400
    Calcium Hardness 320
    CYA 100
    TA 70
    pH 7.4
    Phosphates 2500
    So - I have read the posts related to SLAMing your pool as well as the topics on Phosphates (Good vs Bad). I feel I have a few issues - the Salt and CYA seem high for my pool and my chlorine level is constantly low. My SWG runs 10 hours a day at 100%. The employee at the pool store says I need to take care of the Phosphate level by adding their magic phosphate be gone and that will cure both the algae and FC problem. He even took a sample of my water and mixed in a few granules of their sanitizer and wha-la - my chlorine levels spiked to the correct color on the test chart. I agree with this website's view on FC and plan to take the steps to correct the algae via SLAMing. I would like to SLAM the pool to take care of the algae and keep the FC at a higher stable level but my concern is with the salt / CYA levels. Do I need to do a partial drain to lower these levels? I do not want to start the process if my water is not ready.
    So I'm looking for some help - I have about 8 bottle of liquid chlorine ready to start tonight if the SLAMing process is the right direction. Otherwise what would my first step be? Thank you in advance for any help.
    RB
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: OK - Here's what I got...
    Welcome to TFP!
    What SWCG do you have?
    Dilute your pool water sample 50-50 with tap water and test your CYA again, doubling the result. The test only reads to 100ppm, and higher levels may test at 100ppm too. This will give you an indication of where you are.
    Odds are SLAMing the pool will cure your low chlorine problem.
    Jul 2014
    So Cal
    3
    Thanks for the quick reply John - I don't have a way to test the CYA here at my house, but if it helps I took my water sample to two different stores today. One said 100, the second said closer to 120. Honestly it seems like both stores read the tests and add opinion...
    For the SWG I use the Pentair Intellichlor. The system is no more than a year old. I just recently cleaned both the SWG and the filter cartridges. One thing I forgot to mention is I also use the 3" floating tablets as recommended by the pool store. I mention this because I know it will slowly raise the CYA levels.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    John, I'm not sure the "big name pool store" would do that for him.
    RB, It would be to your advantage to purchase your own accurate test kit. Pool store testing is notorious for being off by quite a margin, especially the CYA test. Check out http://www.troublefreepool.com/conte...its-comparison
    It would also help you to read in Pool School a few articles:
    http://www.troublefreepool.com/conte...ater-chemistry
    http://www.troublefreepool.com/conte...art-slam-shock
    http://www.troublefreepool.com/conte...nate-your-pool
    The test kits can be bought from http://TFtestkits.net
    And Welcome to TFP!
    SW Indiana
    9,199
    Quote Originally Posted by RB03 View Post
    Which Intellichlor? There are about 4 models with different capacities.
    3400ppm salt is exactly what Pentair recommends, so you don't want to lower that.
    The tablets raise CYA fairly quickly. There is no reason you should need them with a SWCG in your pool.
    Oct 2013
    Jupiter, FL
    19
    Are you sure your SWG is working?
    18'x9', IG, Plaster, AutoPilot Pool Pilot Digital Nano SWG (RC-35/22 Cell), 1 HP Sta-Rite Dyna-Glas Pump, Sta-Rite PXC75 Posi-Clear Cartridge System, AquaCal Heatwave Heat Pump.
    Casey's Avatar
    SW PA
    10,461
    RB, Welcome!
    Lets start off with a test kit like the TF100. You can look at the comparison here: Test Kit Comparison
    Then, I would like you to read:
    ABC's of Pool Water Chemistry
    Recommended Pool Chemicals
    How to Chlorinate Your Pool
    Chlorine CYA Chart
    These articles will help you understand your pool water chemistry. Any questions, ask and once you get your test kit, we can start SLAM'ing the pool.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,672
    You are SO on the right track! Finding TFP and asking questions!
    We can and will help you. Just look at the above posts to get you started on what you need!
    WELCOME!!
    Kim
    Jul 2014
    So Cal
    3
    JohnT - I have the IC40 for my SWG. And the reason I am using the tabs is to help add FC into the pool since it has been consistently low. Which is why I think something is off.
    Whalers - my SWG is working - all the lights are green, no error codes and it has recently been cleaned.
    Thanks to the rest for the comments - I have been through the website prior to today and have read the pool school articles which is where I have learned the most regarding the care for my pool. I feel as though I understand the basics, but obviously I am missing something since my levels are a little off kilter.
    Any advice or steps to take would be helpful. I do agree - a REAL test kit would absolutely help as far as getting more info onto this thread so you guys can help out. While waiting for the test kit - should I simply add some liquid chlorine to stabilize the algae until it arrives and we can get a good read?
    Thank you again!!
    Casey's Avatar
    SW PA
    10,461
    Personally, I would hold off on adding anything til you get the kit and can get an accurate CYA reading and do a partial drain/refill as your CYA is too high. That is your first move.
    Jun 2012
    Howell, NJ
    977
    You're on the west coast, so you would be better off ordering the test kit from the other site that sells them. I can't remember it off the top of my head, but someone else here will remember it. If not, I'll find the west coast distributor of the TF-100 and post it for you.
    EDIT: The west coast distributor is poolsupplyworld.com.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
