Page 1 of 4 1234 LastLast
Results 1 to 20 of 63
Thread: Got my Taylor 2006-C first test
    daddycreswell's Avatar
    Jul 2013
    Lebanon TN
    130
    So it came in the mail today, after a little ready I pulled a sample and tested. Here are my numbers with a learning curve I'm sure
    FC 0.0
    pH 8.0
    TA 170
    CH 470
    CYA 30
    To start slamming pool math says 342 oz of 15% bleach to get to 24 FC
    Get pH down 7.3 I need 32 oz of acid
    16 x 32 18,000 gallon vinyl liner inground pool, Compupool SWG, 1.0HP Pentair pump, sand filter.
    Casey's Avatar
    SW PA
    10,453
    Re: Got my Taylor 2600-c first test
    Would you like to take care of that high CH first with a drain/refill or would you prefer to wait? I'll let you decide but you should, consider bringing it down. You're running a high pH and with a high CH, you could start seeing scale on your liner and booger it up.
    Other than that, you're ready to SLAM the pool once you get the pH down.
    Jul 2013
    Lebanon TN
    130
    Quote Originally Posted by Casey View Post
    Any way to figure how much water needs to be removed to bring number down?
    Casey's Avatar
    SW PA
    10,453
    Well, I would start by draining the pool and leaving 1ft of water in the shallow end as to not displace the liner and refill, circulate the water and retest. If you can get the CH to around 200, you should be good. I would imagine you were using Cal-Hypo as your source of FC.
    Jul 2013
    Lebanon TN
    130
    I'm using 5 gallon of pool shock that is 15%.
    Jul 2013
    Lebanon TN
    130
    I'm using 5 gallon of pool shock that is 15%. Also I have hard water at my house, so I'm thinking I'm going to keep having this problem.
    Casey's Avatar
    SW PA
    10,453
    I figured it was from previous visits to the pool store and what they were selling you.
    You can try to harvest rain water. I know other members do that because of it. I believe that's you're only option.
    Can you run a CH test on the fill water and post the results? If it's high, there may be no sense in doing a water replacement.
    Jul 2013
    Lebanon TN
    130
    Yea I can, do I just do a test on from the spigot, or do I mix them?
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Just do a test from the spigot. 😎
    Jeff
    Jul 2013
    Lebanon TN
    130
    Quote Originally Posted by pwrstrk View Post
    Ok thanks, I'll check that out tomorrow. I was hoping my kit would come in earlier today so I could start slamming that way I had all day to fight it, but no luck. Busy tomorrow so I'll have to hit it Monday.
    Casey's Avatar
    SW PA
    10,453
    If you are positive you have high CH in your fill, I would start the SLAM. A water replacement would be a waste. I was just curious as to what it really is.
    Jul 2013
    Lebanon TN
    130
    I'm pretty sure we do, when I wash my cars there are huge spots all over the cars, and the water eats hot water heaters about every 3 years. Luckily for me they have 6 year warranty.
    Oct 2013
    Chapin, SC
    1,141
    I don't remember your numbers from the previous thread. Has your FC always been that low, or is that just a recent condition?
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    Jul 2013
    Lebanon TN
    130
    Quote Originally Posted by timerguy View Post
    I was running around 7.3, I'm hoping I did the FC/CC test correctly.
    Jul 2013
    Lebanon TN
    130
    I tested my tap water this afternoon, it's higher than my pool, it is at 300. So I guess the drain and fill won't do much good?
    Oct 2013
    Chapin, SC
    1,141
    If you're following the very simple instructions for the fas-dpd FC test, there really isn't too much that can go wrong with the results. Btw, a SpeedStir is an invaluable tool for performing your tests. I suggest if you didn't order one, you might consider it.
    May 2014
    Current: Singapore Previous: Clayton, Victoria, Australia
    584
    If the CH of your tap water is higher than your pool, then a drain and refill would increase your CH.
    Member living in areas with high tap water CH usually harvest rain water in order to help keep the CH in check.
    Jul 2013
    Lebanon TN
    130
    What time of day is best to start the slamming process?
    May 2014
    584
    Best to start when you can dedicate a few hours because bleach may disappear quickly during the start.
    It is advisable to SLAM at night so that there is no chlorine loss to sun.
  20. Back To Top    #20
    Jul 2013
    Lebanon TN
    130
    I did my test again on FC, when I put the powder in the water doesn't turn pink so I'm guessing I have no FC
    Sent from my dumb apple products my work makes me use.
    Also do I need to do the acid demand test or the base demand test?
