Results 1 to 10 of 10
Thread: Have a pool install question
    Jul 2014
    Batesville, Arkansas
    6
    We bought a 24" round pool few weeks ago. Right now we are doing ground prep but have a question regarding the liner coping. I have helped install a AGP a few times before. It's been my experience that the liner goes over the pool wall then the plastic
    V coping and then the metal rail over plastic V coping. Our pool come with round coping and round top rails. I see no way that the metal rail can fit over the coping. So question is what goes first, plastic coping, liner or metal rail?
    Jul 2014
    6
    Re: Have a pool install question
    Here are photo of coping & rail
    Jul 2014
    6
    Here are few pics of ground prep.
    Casey's Avatar
    SW PA
    10,453
    Hey Kevin! Welcome to TFP!
    I've never used coping like that BUT, I have a question... What kind of liner are you installing? Overlap, beaded, jhook?
    Oh and can you post a pic of the top plate that receives this coping? Thanks
    Looks like you've been busy!
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Welcome to TFP!
    I'm not sure, but I think the plastic piece goes over the metal once you have your liner installed. The plastic looks to me to be able to expand over the metal to firmly clamp the liner in place.
    I am sure that someone that knows more should be along to help.
    Jul 2014
    6
    Thanks for the welcome! it's an overlap liner.
    Quote Originally Posted by Charlie_R View Post
    Welcome to TFP!
    It does, so it leads me to believe that the top metal rail goes on top of pool wall first then liner and then the plastic coping. The instructions on pool are universal doesn't mention round coping.
    Jul 2014
    6
    Yes very busy going on 3 weeks now. Here are couple photos of top plate.
    Thanks
    Casey's Avatar
    SW PA
    10,453
    Okay... your liner goes over the wall first. The plastic goes over the liner to hold it in place and the metal strip holds the plastic coping strip and feeds into the top plate.
    Jul 2014
    6
    Thanks for your reply. That is the way i thought it should be and have done it that way on another pool but using a v shaped coping. I dont see how the metal strip can go over the plastic. Its even slightly larger than the metal strip.
    Casey's Avatar
    SW PA
    10,453
    You'll probably have to use a lot of pressure to get it on. It should be snug.
