Thread: Out of test supplies!
    Adiharce's Avatar
    Jul 2014
    San Antonio, TX
    24
    I'm out of the DPD powder that came with my test kit. Leslie's does not carry this powder. Is there another product I can use while I await a refill? I'm trying to pass my OCLT and I'm going to not have enough to complete! Argh!!!
    Alex D.
    AG, 17500 gal, Plaster, Sand Filter,Pentair WhisperFlo Pump
    Polaris, Master Temp 400 Pool and Spa Heater
    Pentair Chlorine Automatic In-Line feeder
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: Out of test supplies!
    No, only the powder works. You can dilute your water sample with distilled water to extend the range of the OTO test. 3 parts distilled to one part pool water, test the result and multiply the reading by 4 to get an approximation of your level. Other dilutions will work as well.
    Jun 2012
    Howell, NJ
    977
    Just remember that if you go the dilution route, it won't be near accurate enough to tell if you pass the OCLT.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    Casey's Avatar
    SW PA
    10,427
    Always make sure you order before you run out.
