Results 1 to 18 of 18
Thread: Best $250 ever spent!!!
    Ok - it all started last year when my wife said "why don't we get a pool"!! We purchased a $250 Summer Escape from Wallyworld and it exploded from there. So, everybody knows a little about me here is what the wife says. "You can never leave well enough alone" "You always have to try and improve everything" "It's fine the way it is" - Well I like to tinker and improve anything that I can.
    So here is my pool story and some pictures to go with it.
    So, last year after the purchase I cleared the grass and leveled the area the best I could and up went the pool!!! The kids loved it!! We were very fortunate that a friend of my wife gave us a very small sand filter and pump. I hooked everything up and it was great. My wife complained constantly about having to add this product, add that product, just to keep the level perfect. The street we live on has 9 boys from the age 6 - 10 so every day there was about 7-9 kids in the pool. After a great summer we decided to take the pool down and store it for the winter.
    So, during the winter months I scoured this forum up down left to right looking for every improvement that anyone could think of. I spent countless hours deciding what I was going to do, how was I going to make this better? I started from the ground up.
    This is what I have done:
    Leveled and reveled just to make sure it is perfect. Then the tarp, then the ˝” extruded polystyrene which is held together with 3” gorilla tape. On top of that is a Gorilla Pad, so the ground area is AWESOME!!!! Since the pictures below I have VERY VERY carefully cut the (Gorilla Pad, insulation, and tarp) to fit the pool perfectly so you can’t even see it.
    I searched Craigslist for someone selling pool stuff and found a Haywood 200lb Sand filter and eBay for a 2hp Haywood Pump. I decided to hard pipe everything with 1˝” PVC. I do have 1” PVC going to the heaters (oh I forgot to mention that)!! I built 4 500ft solar panels (a total of 2000ft of black ˝” poly pipe) they are mounted on the roof of the house. I decided to use the skimmer that came with the pool, I just had to cut and sand the bottom to fit a Haywood return fitting so the PVC could connect. I wanted to make sure the pool had great circulation so I added a (kind of) bottom drain. It is another Haywood 1˝” return fitting. Then I added another Haywood 1˝” return for the actual return with a 1” eye. Also, since the picture I have added a fountain to the return line. You can see I had already planned that.
    I decided to go with salt water so the wife wouldn’t complain about the chemicals. I went with a Pentair IC15 SWG. It is perfect for a pool this size; we run it only a 40% and it maintains 3 FC.
    I decided to enclose everything inside a box for protection and noise. I built the box out of pallet word. It has a bottom and is fully enclosed. Inside the box is where everything happens. I have two check valves in the system. One is on the main return from the filter. The other is on the water feed from the house. I didn’t want to have to pull a hose out every time the pool needed water so I piped an irrigation valve in line with the feed from the house to the pool return. I have it on a switch to turn on and off. So if the pool needs water, just hit the switch and it starts to fill once it has enough flip the switch off. If you notice everything has unions so if the pump needs replacing or the sand filter needs any work everything can be disconnected very simply. All of this and NOT one leak!!!
    After 2 weeks of having the pool up I wanted something more!!! We already have speakers outside from the living room for music – WHY NOT VIDEO??? So I went back to craigslist and found a projector for $50. It needed a new bulb and the person selling it wasn’t comfortable about replacing it. I found a bulb on Amazon for $75, so for $125 my kids became the envy even more. I built a shelf out of pallet wood and buried HDMI and outdoor romex to the tree. We do take the projector in the house after we finish watching.
    I think I have mentioned everything here. I do have to say this is the best place to learn about anything with a pool!!!!!
    Richmond, VA
    Soft-Sided - 18' Round 42" depth -- 6,700 Gallons - All 1˝” Hard PVC piped -- Pentair IC15 SWG -- Solar Panel Heaters -- Haywood 200lb Sand Filter and Haywood 2hp Pump
    2 year old
    Projector in the backyard for MOVIE night every night!!!!!
    northrn's Avatar
    May 2014
    Cincinnati, OH
    532
    Re: Best $250 ever spent!!!
    I absolutely love it! I'm sure those boys are the talk of the town! (note to self: check into a projector)
    27' AG 18K Gallons ~ Cartridge Filter ~ Pentair 1.5 HP Pump
    Jun 2014
    Reno NV area
    6
    Wow, Looks awesome!
    Doughboy 24' AG, sand filter, 1 HP pump
    Casey's Avatar
    SW PA
    10,444
    Nicely done!
    ranger_ric's Avatar
    May 2014
    Midland TX
    183
    Over the top with Awesomeness!! Nice Job. I see what you did there. You have the same plan as I do.
    "Honey Look at all this great outdoor pool stuff we have. We really need to spring for a more permanent ABG Pool. Look this sharkline/whatever is on sale. We really should get a nice pool to match our nice backyard!!!
    17500 Gal Above Ground, 1.5HP Dynamo Pump, 250# Pentair Sand filter with ZeoLite. Diver Dave Cleaner. TFP test kit w/SpeedStir, 7 Grandaughters and 1 Grandson swimming every week WooooHooo!!
    May 2014
    mi
    27
    Love the movies. Is that a pool or a whirl pool with that pump?
    Jun 2014
    860
    As Darth Vadar said to Luke Skywalker on the surface of Endor (in my best James Earl Jones voice possible) -
    "I see you have constructed a new Lightsaber....your skills are compleeete!"
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    574
    Awesome job! Totally envious of the outdoor theater. You are lucky to have a wall close by to project on. I'm still designing a screen set up that can be stretched between two posts and easily taken down when not in use.
    24'x52" Artesian w/ Portifino liner - Hayward 1hp powerflo matrix w/24" sand filter - AquaTrol RJ SWG. Solar heating to come. -
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    I'm hoping to expand my outdoor pool experience next year. Home Depot has a blow up 12 foot projector screen for about $130. That would be an option for anyone without a place to put a screen. I've always thought it would be cool to float in the pool and watch a movie.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    May 2014
    Glenshaw,PA
    19
    Very nice!
    Susan😎
    Swim N Play Yorkshire 15'x48" round AGP
    Pentair Clean and Clear 75 sq ft Cartridge filter and 1 hp Optiflo pump
    Hayward Aquabug cleaner🐞 and Taylor K-2006 test kit
    Sep 2012
    Gardiner, ME
    165
    Very nice!
    24 ft Sharkline Matrix AG
    Waterway 1HP 2SPD Sand Filter 100lb sand capacity, using 50lb of ZeoSand
    TAYLOR K-2006 test kit.
    Installed Spring 2013
    16x16 Deck Going up Soon.
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    nicely done!
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
    May 2012
    NW PA, halfway between Pittsburgh and Erie in the PA snowbelt
    159
    Wow, the folks looking out the kitchen window at the pool are huge! LOL
    Mike
    22' round Intex UltraFrame pool, Intex 633T 2500gph paper cartridge filter/pump
    with broken Intex SWG, using bleach this year
    TF-100 test kit
    jmcdtucson's Avatar
    Jun 2014
    317
    Come to my house next!
    Intex 12'x24'x52"
    8,403 gallons
    Intex SF60110 2450 GPH Sand Filter
    Intex CS8110 SWG
    Aquabot AJET121I Pool Rover S20-40
    Apr 2010
    Buckeye, AZ 85326
    619
    Awesome!
    11,872 Gallon IG Shotcrete play pool
    Blue Granite Pebble Sheen finish
    Hayward SwimClear c4025, Navigator & Tristar 1.75hp pump
    2' Powerfall
    May 2014
    CBS, Newfoundland, Canada
    13
    Awesome setup... gotta get me a projector
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    I too have a projector outside over my pool... Its the only way to spend summer.... I'm using it inside at the moment, but its winter here for me.... But I cannot wait for the summer to hit... Just three more months...
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    Jul 2014
    Brunswick, Ohio
    1
    Awesome! I love the projector idea! We have an old one that I can use just for this!
