Results 1 to 9 of 9
Thread: stenner check valve keeps going bad
    I have had the pump for 3 years and this is the second check valve to go bad. When it happens my bleach tank slowly fills up with pool water.
    I saw references to the fact that the pump should prevent backflow and it probably does, but a little still probably backflows.
    I saw references to cleaning the check valve, but couldnt find the instructions
    How often are people's check valves failing and if they are failing this often, does anyone have a better source?
    17,800 gallon, IG pool, 595 sq feet (17x35x4.5 avg rectangle), Hayward 525 cartridge filter, diamondbrite, 2 hp 2 speed hayward tristar filter, Stenner 45mhp10 automatically chlorinating
    mikespoolfl's Avatar
    Mar 2011
    Florida
    179
    Re: stenner check valve keeps going bad
    On the 45mhp10 the max pressure is 100 psi. That's a lot to over come to have back flow because it has to make it by 2 rollers and the duckbill also. How long has it been since you replaced the tube.
    Screen enclosed 17K gal 16x30 IG with Diamond Brite finish, elevated 4 jet spa with spill over, Twin dolphin fountain, Hayward Ecostar pump[ Pentair intelliflo VS, Filter Sta rite Posi-Flo PTM 100, Aqua Cal heat pump, Tiger Shark QC robotic cleaner.
    Stenner peristaltic pump model 45MPHP10, 15 gal storage tank. TF 100 with Speed Stir.
    Quote Originally Posted by mikespoolfl View Post
    Replaced the tubing about a year ago. Looks like the check valve isnt bad though. Poked around at the membrane with some pliers (there was some sediment caked in there) I took off the tubing and turned the pool filter pump on and no water came backwards through the check valve.
    I had the stenner pump set to run all afternoon and it took a few gallons out of the tank this afternoon (mostly very dilute chlorine) so it might be ok.
    Ill check the tubing on the stenner pump
    If the check valve is good, but the tubing is going bad, how would pool water get into the bleach tank?
    22,548
    There's almost no way that pool water can flow backwards. It would have to flow back through the check valve and the pinch rollers before it would ever get to the tank. If the pump is working there's no way liquid can back up through the pump.
    There are two ways for the pump tube to fail. One is to break or split, and the other is for the tube to lose it's elasticity and go flat. If it breaks, either the pump won't prime or it will leak fluid out of it. Depending on where the break is. If the tube goes flat, the pump won't pump anything.
    If you're getting water in the drum I'd look at it being rain, etc..
    its definitely not rain and the pump is definitely pumping. I set it to run for 24 hours and it cleared the tank (I ended up doing this twice).
    Filled the tank with bleach again it drained it about 1/4 and now is full again.
    This is driving me nuts. I dont know where to start.
    22,548
    The rollers press against the tube using spring pressure. The only way for water to flow backward through the pump and into the tank is if one or more of the rollers lost it spring tension and is not pressing on the tube hard enough. Pull the pump out and remove the bottom cover and see if that's the case.
    Also I missed answering about the duckbill (Check Valve). If you take the check valve housing apart in the middle you'll be able to see the duckbill. It's just a rubber piece with a tiny split in it and calcium buildup or a tiny bit of trash will cause it to leak. You can buy just the duckbill.
    My check valves were failing every 3 months with acid injection. I just removed the check valve and inject directly into the duckbill. No issues with backflow and all is well
    28000 gallon IG pool, 3.5ft - 8ft deep, Stonescapes Tropics Blue Interior, Pentair Intellichlor SWG, Pentair Quad DE 100 filter, Pentair Intelliflo VS-SVRS, Whisperflo 3hp (water features), A&A Max in floor cleaning, Pentair Easytouch 8 Automation, Screenlogic II, Pentair Mastertemp 400k BTU heater, Pentair Intellichem with acid injection via stennar pump, 9'x7' spa with Infiniti edge
    I bet that's it I haven't oiled the mechanism either would surprise me if it is stiff
    Ok I think I found the problem. I bought new tubes, when I went to replace the tube I noticed that the old tube was a full inch longer than the new ones. At first I thought I bought the wrong tubes, but apparently they stretch and thus get narrower so they are not sealed all the way. They would still pump bleach when it was on, but when off they werent sealed. It still makes me wonder about the check valve, but ill see if this works.
    The pool is 3 years old, but Im pretty sure I replaced the tubes once. Possibly not though
