Results 1 to 16 of 16
Thread: Algae Problems
    BB BMW's Avatar
    May 2013
    Alabama (Roll Tide)
    41
    Algae Problems
    I've been using the BBB method for about two years now and have not gotten control of my algae problem.
    After opening the pool and balancing the water PH and CL, then vacuuming, etc. the water looks great for about 2-3 weeks.
    I test the water every other day keeping the CL, FC and PH in balance. The problems start after it rains. The pool almost turns green over night.
    I add bleach when needed, I add borax when needed and baking soda when needed. I have an automatic chlorinator that I put one 3" tab in a week.
    The pool is only used be me and my wife, mostly on weekends.
    Something I must be missing or doing wrong to lose control this fast.
    Please help with suggestions, ideas or other methods that would prevent the algae invasion.
    Thanks in advance
    16' x 32' Vinyl IG, 15K Gal. (not SWG)
    1 HP Hayward Super-Flo Pump, Pentaire Sand Filter
    Hayward Automatic Chlorinator
    Polaris 380 Pool Cleaner w/booster pump
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Re: Algae Problems
    In balance? What are your numbers? FC, CC, CYA, CH, TA, PH
    Do you understand the FC/CYA relationship as taught in pool school?
    Do you understand that tabs are adding CYA and really aren't BBB? One of those 'B' is bleach.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    Jun 2012
    Howell, NJ
    977
    Re: Algae Problems
    It's going to be very difficult to help you without a full set of test results, especially CYA. Do you have the recommended test kit? If you are using tablets, I wouldn't be surprised if your CYA is high.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    BB BMW's Avatar
    May 2013
    Alabama (Roll Tide)
    41
    Re: Algae Problems
    I thought you were supposed to use 1 tablet a week in your chlorinator.
    Any ways, here are the test results:
    TA = 50
    CL = 1.2
    CC = 0
    FC = .5
    TC = .5
    PH = 7.6
    CYA = lower than 30 (thru the test I filled the tube all of the way up and could still see the black dot on the bottom)
    I guess not enough stabilizer. Going to pool calculator, but would still like suggestions
    Jun 2012
    Howell, NJ
    977
    Re: Algae Problems
    I assume those numbers are from the K-2006 or TF-100, correct? Does your pool currently have algae right now? If yes, you will need to SLAM your pool to get rid of the algae. Link can be found in my signature. If no, your FC is too low for your CYA. You should be targeting 6 ppm, and never dropping below 2 ppm. Those tablets change too many variables at once, which is why they aren't recommended until you get some experience with your pool. You have to really keep an eye on FC, pH, and CYA when using them.
    John
    May 2014
    Current: Singapore Previous: Clayton, Victoria, Australia
    584
    Re: Algae Problems
    If your CYA tube was cloudy but you could see the dot, then you have some CYA but less than 30.
    I would suggest that you switch to a 10ml sample for your FC/CC test as it saves reagent and is precise enough.
    I would also suggest you read how to chlorinate your pool.
    BB BMW's Avatar
    May 2013
    Alabama (Roll Tide)
    41
    Re: Algae Problems
    Quote Originally Posted by JohnN View Post
    I'm using the Taylor K-1005 kit. When I first joined this site, I thought I read somewhere on here to use one 3" tablet per week. Should I stop using them?
    I do currently have green algae.
    Using 3% bleach with a FC target of 6 or 7. PH is usually around 7.5 - 7.8, it's pretty stable. I'm adding some stabilizer thru a sock now. I started last night.
    Target is 40-50. I do have a dead frog or mole in the skimmer basket every now and then. I know these must have an effect on the chlorine. But those are something I have to deal with.
    The pool is clearing slowly. It is a light green now, but looks kinda clear for green (not cloudy). Should I just continue slamming it until it's clear?
    I have read "how to chlorinate your pool" and I'm using the 3% bleach, baking soda and 20 mule borax when needed. I test FC and PH every day or every other day.
    Quote Originally Posted by Abigail K View Post
    What do you mean by switching to a 10ml sample for FC/CC?
    May 2014
    584
    Re: Algae Problems
    Quote Originally Posted by BB BMW View Post
    Sorry, I mis-read the CL 1.2 and thought you were using a 25ml sample for the FAS-DPD.
    BB BMW's Avatar
    May 2013
    Alabama (Roll Tide)
    41
    Re: Algae Problems
    Ah............that confused me since I'm still learning this process.
    BB BMW's Avatar
    May 2013
    Alabama (Roll Tide)
    41
    Re: Algae Problems
    OK...I've been slamming (shock process) my pool, it is clearing.
    Should I discontinue using the 3" tabs in my automatic chlorinator and just use bleach?
    Waldog's Avatar
    May 2014
    Christmas, FL
    189
    Re: Algae Problems
    Don't use tabs unless you go on vacation and someone can't add bleach for you. The tabs will continue to bump up your CYA past the point of diminishing returns.
    Installed May 2014 - 16' x 48" Summer Escapes Pro Series Pool AG Vinyl (6,000 gal) - Intex 2650 Sand Filter - Christmas, FL
    Re: Algae Problems
    I agree...no tabs unless you are going on vacation. I've gotten heavy rains this season and I will bump up my chlorine by adding a gallon of bleach during a heavy rainstorm. It's not exactly scientific and the true TFP mods might not like my advice. I do know that 1 gallon will raise my FC by 5ppm. I also know that we get such huge deluges of rain, that I'm going to have an inch or 5 of pool water go out the drain on the waterline. Plus, rain will introduces all sorts of organic a so yeah...I dump in a gallon for good measure. I'm in houston though so if you don't have heavy rains, you might not need to do this.
    17,000 inground gunite pool finished June 2013. Pentair variable speed something or another. Polaris cleaner, inline rainbow chlorinator. Using trichlor until CYA reaches 50-60.
    BB BMW's Avatar
    May 2013
    Alabama (Roll Tide)
    41
    Re: Algae Problems
    Quote Originally Posted by Dreampool13 View Post
    Well I'm Alabama and it's raining now. ahhhhhh just about got the pool cleared up and now.......
    northrn's Avatar
    May 2014
    Cincinnati, OH
    532
    Re: Algae Problems
    and now you keep doing what you were doing. testing your water and dosing with bleach. algae doesn't stop growing just because it rains so you shouldn't stop fighting it when it rains either.
    27' AG 18K Gallons ~ Cartridge Filter ~ Pentair 1.5 HP Pump
    Re: Algae Problems
    Okay so you are in the south! It's been incredibly rainy. My cya was at 70, but now it's around 30 because it's been incredibly rainy here. The good news is that you only need 2-6 ppm of chlorine and that's easy to maintain. Unfortunately 1 trichlor puck a week won't do it. Each trichlor puck will add 1.3 ppm if cya. If you are at 30ppm of cya, you could safely use 20 pucks over the course of a few weeks to bring your cya to 55 or so. Or you could do what I'm doing and keep your chlorine between 2-6 cheaply and easily with liquid bleach. Of course if you have algae you will need to slam, but otherwise an average of 4 will be perfect for your chlorine. And if the rain clouds roll in...be a little heavy handed with the bleach. And where did you find 3% liquid chlorine? I buy Clorox from Target and it's 8.25%.
    This is happening now so Im adding an extra gallon to make sure I stay ahead of algae.
    BB BMW's Avatar
    May 2013
    Alabama (Roll Tide)
    41
    Re: Algae Problems
    Quote Originally Posted by northrn View Post
    No the rain seems to help the algae grow not stop.
    I'll check the percentage of the bleach again. (it may be 6%)
    I've added CYA last Sunday and will check it again this weekend to see what level it is at now. I read that it can take up to a week to show new level.
    I'm going to stop using the tabs for now and see how it goes. Yes the rain is making it hard to keep things balanced.
