Thread: Starching the pool with water in it
    Hello
    I have a problem with my round above ground pool.
    I filled it with water but the bottom of the pool didn't starch as i hoped and i have some pretty big folds in my pool.
    Is there a way to starch it without draining the water??..... I know its a long shot, but asking cant do any harm....
    Thanks
    Lior
    ranger_ric's Avatar
    May 2014
    Midland TX
    183
    Re: Starching the pool with water in it
    "Stretch"?
    Water weighs around 8.4 lbs per gallon. So once you fill the pool you have 1000's of pounds pushing down on the liner. Therefore it is impossible to move the liner with that much water on it.
    To remove the wrinkles you will have to drain the pool.
    17500 Gal Above Ground, 1.5HP Dynamo Pump, 250# Pentair Sand filter with ZeoLite. Diver Dave Cleaner. TFP test kit w/SpeedStir, 7 Grandaughters and 1 Grandson swimming every week WooooHooo!!
    Casey's Avatar
    SW PA
    10,461
    Ric has given you the same answer I would have.
