Thread: Minimax NT won't start
    Jun 2011
    Toronto, ON
    22
    Problem started with short cycling which I never figured out now it won't start at all. Went a day without firing next day it ran all day trying to get the temperature back up, then yesterday wouldn't fire again.
    It will try several times then show an E04 code, if I leave the breaker on it will continue to try even with the error code.
    It buzzes when it should start. The fan spins freely so I don't think it's the blower.
    Anything I can check on my own or do I need a service tech?
    18 x 38 IG vinyl modified roman, sand filter, swg, 1hp pump, raypak ng heater
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Re: Minimax NT won't start
    If the fan spins freely but won't start, its the run/start capacitor on the motor. I would also pull out the motor and verify that the squirrel cage is still intact. Short cycling is sometimes bad limits.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Jun 2011
    Toronto, ON
    22
    Thanks very much for the reply Paul.
    Is the capacitor replaceable on its own or am I looking at replacing the whole blower assembly?
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    You can replace just the capacitor. Remove the top and you will see the blower motor. You do want to remove the blower to check the condition of the squirrel cage. If the cage is shot, then you need to replace the entire motor which comes with a capacitor.
    Paul
