Page 1 of 9 1234 ... LastLast
Results 1 to 20 of 171
Thread: New pool build and deck Apex NC
    Jun 2014
    Apex nc
    95
    I've just put a deposit down on an Aqua Leader Blues 30'x52" AGP package with SWG, 150lb Hayward sand filter with zeosand and 2 speed 1.5hp Hayward pump. I'm purchasing through Rising Sun in Raleigh. The pool is on order and should be in in 3 weeks.
    I'm planning to do the deck myself. My pool area has about 2 feet of fall in it. I've already got a 12x30 deck that I will have to come off of and down about 4 feet to the pool deck. Here's what I've drawn up so far for my deck. It will he 50'x 42'. The deck will be 16 feet on the from side of the pool, 6 feet on the sides and 4 feet on the back. What do you think?
    Casey's Avatar
    SW PA
    10,448
    Re: New pool build and deck Apex,NC
    Very nice! That's a big deck! Good luck with your build and please do post pics along the way.
    Jul 2012
    Cary, NC (Raleigh)
    69
    Used Rising Sun for our pool also. A bit different being IG but overall have no complaints with them and were great to work with. Good luck on the build.
    18x30 Freeform In-ground Vinyl Lined. 11,500 gallons.
    4 returns, 2 skimmers, 2 main drains.
    Hayward TriStar 1hp 2-Speed Pump. Hayward S244T Filter.Hayward Goldline Panel + SWG.
    Polaris 280 cleaner. AquaComfort 75k BTU Heatpump
    TF-100
    Jun 2014
    Apex nc
    95
    Thanks. Will post plenty of pics.
    Jun 2014
    Apex nc
    95
    So my build started 7/8. My back yard slopes quite a bit. I knew this in advance.
    The installer, not rising sun, but a person contracted by them showed up with a crew ready to go. I showed them where to start and they got to work.
    The contractor was taking dirt he was digging and placing it on the low side of where the pool was to go. He got it how he wanted it and I went out to inspect it. It was soft and there was no way I was going to pay to have my pool placed on it. I inquired about him digging down and placing the pool on hard ground. He measured and determined it would be $600. I told him to get to it and he did. He returned with his crew this afternoon to do the install.
    Jun 2014
    Apex nc
    95
    I'm doing all the electrical currently on my own with some help from a few friends. I trenched for the sub panel yesterday and ran all the wire and conduit today.
    Jun 2014
    Apex nc
    95
    It was let when the installer got done so we only got 2" of water in the pool from my well. We have 4 water trucks coming first thing in the AM.
    Jun 2014
    Apex nc
    95
    This might be a double post but the first attempt isn't showing currently.
    Our pool is a 30' aqua leader blues resin pool with a saltwater system.
    Here's a few pics of the install
    Jun 2014
    Apex nc
    95
    I'm currently doing the electrical with some help from knowledgeable friends. Yesterday I trenched for the sub panel and today I ran the wire and conduit.
    You can see how much slope there is to my yard.
    Now comes completing the wiring and doing all the bonding(clueless but learning slowly from the net and TFP) and running a French drain and doing some refining to the dirt around the pool.
    Then the 50'x42'+ deck will get rolling.
    Mercy Lord help me.
    Casey's Avatar
    SW PA
    10,448
    So glad you had the installers remove that dirt and get to solid virgin soil. He should have known better than to pull an under handed stunt like that. Good for you for catching it because it could have been disasterous. Ghesh... Keep posting pics!
    P.S. Your yard didn't look that bad but with the pool in... wow!
    Jun 2014
    Apex nc
    95
    Got to doing all my wiring yesterday and got to looking at my pump. No where could I find that it was 2 speed. Emailed a pic to the pool company. The installer will be out to install my 2 speed pump on Monday...
    Apparently wrong one was installed
    Jun 2014
    Apex nc
    95
    I'm using tapatalk to access the forum. Can someone tell me who I contact about purchasing the test kit. I don't exactly trust the pool store.
    Jun 2014
    Apex nc
    95
    So I ran a 60 amp breaker in my home 200 amp service with 4 #6 wires and a #10 ground to a 100 amp subpages at the pool on a 65' run from the house.
    I ran 2 gfci 20 amp breakers in the box.
    I have I have one dedicated circuit for my SWG controller which my motor plugs in to. The I have the a double box run in the other with one being courtesy and the other running my pool light.
    Jun 2014
    Apex nc
    95
    Can I get my thread moved to the above ground pool section
    Jul 2014
    Medina, Ohio
    55
    Looks good. Your install is similar to mine (2' slope, connected with deck). I'm building a 27' round wooden AGP. Almost there....
    Good luck!
    Jun 2014
    Apex nc
    95
    Awesome. Best of luck. I'm going to run my French drain today hopefully.
    Coonspool's Avatar
    Mar 2013
    Princeton, Indiana
    85
    Are there any water shut off valves installed in your plumbing lines? I would suggest that, they are nice!
    21' x 54" AGP Heritage 12,000 gallons.
    Hayward Power-Flo Matrix SP15922S 2 Speed 1 HP
    Hayward Pro-Series S244T 24"
    My SLAM Another swamp, is it worth it? Drain or gain?
    Jun 2014
    Apex nc
    95
    Yes.
    I did the in skimmer water bonding.
    My pastor from church was an electrician for 20 years. He can today and informed me of a few things I need to do so I can pass my inspection. Lucky for me, he's going to come over Tuesday and help me.
    So yesterday we had 4 inches of rain and needless to say I had some sludgy mud around my pool. Spent 6 hours today in the trench shoveling and sloping my sides getting ready to run the French drain tomorrow.
    Jun 2014
    Apex nc
    95
    Spent another 7 hours in the trench with the help of a buddy. Had another friend bring me a load of gravel and wahla, French drain.
    Sad thing is as I was happily finishing my French drain, all I could think about was that I'll have to move the rock to set the posts around the pool.
  20. Back To Top    #20
    Jun 2014
    Apex nc
    95
    Today I lucked upon an awesome deal. There was an apartment complex in Raleigh that had changed their pool furniture. They were selling sitting chairs for $5 and lounge chairs for $10. Best $110 I've spent lately got me 8 lounge chairs and 6 sitting chairs. They are in awesome shape and don't even looked used.
