Results 1 to 13 of 13
Thread: Does the pool math calculator work with cell phones?
    Jun 2014
    clinton
    25
    Does the pool math calculator work with cell phones? I plugged my #'s in and when i click calculate it turns blue for a sec, but nothing happens.
    Jun 2012
    Howell, NJ
    977
    Re: Does the pool math calculator work with cell phones?
    It works fine on my Galaxy S4 using the Chrome browser.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    daddycreswell's Avatar
    Jul 2013
    Lebanon TN
    130
    Works on my Galaxy S5, but I also found this and it seems to work also. It's for Android https://play.google.com/store/apps/d...plb.pool&hl=en
    16 x 32 18,000 gallon vinyl liner inground pool, Compupool SWG, 1.0HP Pentair pump, sand filter.
    Casey's Avatar
    SW PA
    10,421
    Quote Originally Posted by daddycreswell View Post
    Sent from my dumb apple products my work makes me use.
    This is the one I use.
    Jun 2014
    clinton
    25
    Thanks! Ill give it a try
    Jun 2014
    860
    Works on iPhone 5 with Chrome browser.
    Jun 2012
    Indiana
    81
    I bought the pool calculator app for my iPhone because my wifi doesn't quite reach my pool, plus it is not user friendly for seeing the fields and inputting data in the browser. The app works, but was pricey (for an app), and it forces you to set up your pool specs EVERY time you open it. My guess is the developers haven't updated that because they don't actually maintain a pool with it. I usually just go in the house and dust off the laptop instead, much faster.
    Jess :) from southeastern Indiana, USA
    27' x 54" ~17,600gal AG round
    Waterway Ecco 22", 250# oval sand filter 2.6 SF, 55 GPM
    1.5 hp 1-speed pump
    pool DOB July 2012
    mac.dblues's Avatar
    Jul 2013
    Arkadelphia, AR
    321
    +3 This app is great. I use it every time I test. When you set your target results a little chart pops up with several different methods listed. TFP just happens to be one of those lines.
    Mac.Dblues and ProfessorDaisy's Lower Arkansas Pool Install
    Intex UltraFrame 20ft x 52in deep, 9,400 Gallons / Approx 78,500 lbs, Intex 1600 GPH, 14" sand filter, Hayward Dyna-Skim SP1091LX, Taylor K-2006, SpeedStir, Sample Sizer
    First Fill May 2014, Deck finished June 2014, Mods happening probably on a continuous basis. Stay tuned.....
    Jun 2013
    East TN
    309
    You can save the poolmath.html file on your phone and open it with a browser. You can view it offline. I used pool pal for android but you dont have the effects of adding chemicals there.
    18,000 Gallon Aboveground. Sand Filter with 2HP 2 speed Pump.
    mac.dblues's Avatar
    Jul 2013
    Arkadelphia, AR
    321
    Quote Originally Posted by easttn View Post
    I either don't understand what you mean by you can't see the effects of adding your chemicals or they have upgraded the app. You set up your target levels, input your readings, and it tells you how much of what chemical to put in to change your levels to your target. The effect of your chemicals should be your target.
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    Mac.dblues,
    I believe easttn is talking about the section at the bottom of the pool calc page that shows what happens when you add X amount of a chemical to your size pool.
    Thanks for reading... - Tony
    Da' Pool: Intex 15'x42" 3284gal AGP EasySet (Inflatable Ring) - (Summer 2014: 27' round EW /w 6.5' deep end @ 22,500gal)
    Pump & Cart Mod: 1000gph Cart. 5ft² - 2 nylons, 24/7 OP. Traps bugs/bits, lasts longer/cleans easier = Happier Pool Owner!!
    The Bible for a "Trouble Free Pool" life = PoolSchool, the BBB method a TF100 test kit(Recommend Kits Compared). - Cleaning a Sand Filter
    Water looks like GLASS, if yours doesn't...SLAM IT! Feels nice and never been happier!!! :D
    mac.dblues's Avatar
    Jul 2013
    Arkadelphia, AR
    321
    Quote Originally Posted by y_not View Post
    Mac.dblues,
    Sent from my PC36100 using Tapatalk 2
    That's probably it. I don't go that far down usually so I forgot about it. And rarely use that calculator since installing the Pool Pal app. Maybe the developer will read this thread and consider adding that feature to their app.
    Jun 2013
    East TN
    309
    Quote Originally Posted by mac.dblues View Post
    The effects of adding chemicals are not in the pool pal app but it is still a good app. They are in the pool calculator if you just save the page/html file and open it with a browser. The pool pal app allows you to log what your results are and will allow you to log multiple pools if that is your game.
