Thread: Backwashing Frequency
    TrevNJPool's Avatar
    Jul 2014
    atco/nj
    142
    Every time I vacuum on filter I have to backwash when I'm done. Is this normal? I have completely rebuilt the filter. New sand, multiport, laterals and shaft. Not sure if this is normal or not.
    My normal pressure is around 12 and can jump up to over 20. It isnt a whole lot of gunk either. Mostly some sand and dirt. A few small pieces of leaves and some beatles and spiders. Maybe a small toad or two
    40x18 Lazy L Rectangle
    29500gal IG w/ vinyl liner
    HAYWARD S244T 300lb sand filter
    Hayward Super Pump 1 1/2hp
    Re: Backwashing Frequency
    Needing to backwash after vacuuming is common enough. You would be able to go longer between cleanings with a larger filter.
    TrevNJPool's Avatar
    Jul 2014
    atco/nj
    142
    So I guess the 300lb hayward filter is too small for the pool?
    There are different measures of what is "too small". Your filter is a little above the minimum size, but well below the ideal size. For a pool that size I would use a 600 lb sand filter.
    TrevNJPool's Avatar
    Jul 2014
    atco/nj
    142
    Great, another thing the previous owner screwed up for me.
    Mar 2014
    Las Vegas
    288
    When it comes to filter size, I say go with the biggest one you can afford. The biggest advantage is less frequent backwash/cleaning that you have to do.
    12000 Gallon IG Plaster built 2/15/2014. Jandy 340 sg ft 127 gpm filter, Jandy 1 HP stealth pump. Circupool RJ-45 SWG (overkill). TF-100 with Speed Stir.
