Thread: Chem question about PH accuracey when FC is above 10.
    Jun 2014
    Central Florida
    36
    There are chlorine neurtalizer drops when conducting a TA test. . Why can't drops be added when the FC level is higher to get an accurate reading of PH?
    22,000 gallon in ground, gunite, Hayward pump 1.5 hp and 36sq DE filter. Pool installation date unknown, at least 10 years. Screened enclosure.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,015
    Re: Chem question about PH accuracey when FC is above 10.
    http://www.troublefreepool.com/threa...-FC-pH-testing
    Check my response and follow the link
    Jun 2014
    Central Florida
    36
    Very informative. Thanks.
