Thread: cya and chlorine level
    Apr 2014
    Stony Brook, NY
    159
    I currently have my chlorine a bit high due to my wife adding too much bleach this morning. I'm fighting getting my cya in the 70 range, especially with the 5 inches of rain I had last weekend. My question is, is my current reading of 40 of cya correct, even with the chlorine reading at 8 or 9? Does chlorine levels mess up cha readings?
    14000 gallon 16x32 roman in ground vinyl, Hayward 140k heat pump, swg, de filter 1 1\2 HP v.s. pump. Built in June 2014. Tf100 test kit.
    38,248
    Re: cya and chlorine level
    FC does not affect the CYA test.
    The only real interference is that the pH test is inaccurate when the FC > 10ppm.
    Apr 2014
    Stony Brook, NY
    159
    OK, thanks
