Results 1 to 15 of 15
Thread: Low ph, high CYA, should I add borax?
    surfhawaii's Avatar
    May 2011
    Kailua, Hawaii
    63
    Just added a bunch of CYA and ph has dropped to 7.0 (or below). I read in here that CYA affects ph but should I add borax to bring the ph level up or just leave it? TA = 70.
    Ben.
    22k gallon, Sand filter (Triton II TR 100)
    IG tile
    Pentair VS pump
    SWG
    Sundance Chelsee spa
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    How has your PH been in the past ? By that I mean was it pretty stable or does it rise. Do you have any water features ?
    You could leave it alone and see if it comes back up on its own. If it doesn't then raise it up.
    What CYA level did you shoot for ? 😎
    Jeff
    surfhawaii's Avatar
    May 2011
    Kailua, Hawaii
    63
    Re: Low ph, high CYA, should I add borax?
    over the past years, the ph typically rises and occasionally I add muriatic acid to lower it. that's why I was a little surprised to see it this low (haven't had this before). no water features. CYA was at zero so I add 8 lbs. might have overdone it because now it's ~90 (have trouble reading this test). hoping 90 will be ok.
    IG tile
    Pentair VS pump
    SWG
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    90 is a bit high. For a non SWG we recommend 50 at the high end. Me personally I would drain some water off and replace it to lower it. It's your choice. You just have to stay on top of your FC so you don't get algae. How are you chlorinating your water ?
    In the future you should bring the CYA level up in steps so you don't over shoot.
    Jeff
    surfhawaii's Avatar
    May 2011
    Kailua, Hawaii
    63
    I use bleach. yea, should have taken it more slowly on CYA...just lazy. understand the draining thing, done that before, we'll see. my first concern is the low ph, is it a danger to swimmers?
    IG tile
    Pentair VS pump
    SWG
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Not a danger. May burn the eyes. Raise it up a little if it makes you more comfortable. 😎
    Jeff
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,683
    Unless you just filled it with water doesn't having a zero CYA reading raise a red flag that something is wrong. CYA doesn't just disappear and adding 8lbs of CYA to a 22K pool looks to bring it up to near 50.
    I would be suspect of the zero reading and also now wonder if you are doing the test correctly getting the 90
    http://www.youtube.com/watch?v=NxaqoW-_MCs
    Solar Blanket, Well Water, Borax Added. 76
    surfhawaii's Avatar
    May 2011
    Kailua, Hawaii
    63
    yea, I think you're right. it wasn't zero to begin with, test only goes to 30, I made the bad assumption it was zero. would have been smarter to only use 4 lbs CYA, wait a week and retest.
    looked at your link, I do this correctly. it's just hard sometimes to see when the black dot COMPLETELY disappears. wish there were an easier test method.
    IG tile
    Pentair VS pump
    SWG
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    They do have a 50 ppm comparison test available. It'll give a feel for what to look for in the test. It can be tricky. You are able to retest a couple of times with the same sample to verify your reading. 😎
    Jeff
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,683
    What test kit are you using that only goes to 30 ??
    That CYA test is ... different. Would be nice if there was some other way as I'm always second guessing myself with that little black dot
    Oct 2013
    Chapin, SC
    1,141
    0 to 90 would have required 16.5 lbs of Stabilizer
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    surfhawaii's Avatar
    May 2011
    Kailua, Hawaii
    63
    [QUOTE=kiss4afrog;701728]What test kit are you using that only goes to 30 ??
    I use the Taylor K-2006. I mean the lowest number the tube goes to is 30, which is at the top of the little tube.
    IG tile
    Pentair VS pump
    SWG
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,683
    Gotcha .
    Quote Originally Posted by timerguy View Post
    But he wasn't going to 90 he just thought he was at zero and was trying to get some in there.
    Oct 2013
    Chapin, SC
    1,141
    Quote Originally Posted by kiss4afrog View Post
    Gotcha .
    He says it's now~ 90. He says he doesn't really know if it was zero. But my point was 8 lbs of cya can't take it to 90.
    surfhawaii's Avatar
    May 2011
    Kailua, Hawaii
    63
    Thanks for all the help. Update. We had a big rain the other night, pool almost overflowed. Ph now at 7.4. I love it when things resolve themselves but learned the lesson of adding CYA slower next time.
    IG tile
    Pentair VS pump
    SWG
