Thread: Natural Chemistry
    Jul 2014
    Crowley,Louisiana
    26
    Natural Chemistry
    Any opinions on Natual Chemistry products as a monthly main. program? Such as from the start with the Foundation base, the phosphate and organic reducing liquid and the multi-mineral w/salt for SWG care and maintenance.
    38,251
    Re: Natural Chemistry
    Welcome to TFP!!!
    My only thought is that just about everything you mentioned is not needed for any reason and thus a waste of money. Why put chemicals in the pool that are not needed and why pay more for the same chemicals that you can get from a hardware or grocery store just because they slap a fancy name on them?
    Check out Pool School starting with these:
    ABCs of Water Chemistry
    Recommended Pool Chemicals
    How to Chlorinate Your Pool
    Jul 2014
    Crowley,Louisiana
    26
    Thanks will check those areas. There is just so much to read and not enough time.
    Jul 2014
    Crowley,Louisiana
    26
    Do you need a phosphate test to check for algae or potential algae problems? Or will it show in other tests?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Opinions? Sure.
    I've never put any of the above in my pool and it has remained clear and swimmable (although too cold to do so at times) 365 days a year for the last 4 years. No algae blooms at all.
    38,251
    Phosphate levels are meaningless and just a way for pool stores to sell you over-priced magic potions
    They are food for algae. But, if you maintain adequate FC levels (which are a function of your CYA), then the algae can not live in the first place, so who cares how much food there is?
    Keep reading and asking
