Thread: Noisy pump with broken bonding lug
    Jun 2013
    Wilton, CT
    1
    I have a 3/4 hp Hayward Max-Flo pump (SP2805X7) that I think is 9 years old. It has 2 problems.
    (1) The motor bonding lug is broken off or missing so I can't attach the bonding wire.
    (2) It's a bit noisy (see video)
    http://youtu.be/_oh5br3V-zc?list=UUf...rVzPT42zYv4woA
    I checked the manual and don't see any replacement part numbers for a bonding lug. I went to a hardware store and they didn't know how to find what I needed. Any ideas?
    I suspect the noise may be due to bad bearings, but can someone confirm that? I considered options like replacing (1) the bearings and seal, (2) the motor or (3) the whole pump. But considering we may be moving next year and this might be our last pool season, there isn't much incentive to spend a lot of time, effort or money to fix this unless it's a safety issue. Is there any harm in continuing to use a noisy pump?
    Thanks for all your help,
    Brian
    14k gal, AG vinyl, 3/4 hp Hayward Max-Flo pump SP2805X7, 1.7 sqft Hayward S180T sand filter, Hayward Chlorine Feeder CL-200
    38,235
    Re: Noisy pump with broken bonding lug
    Welcome to TFP!!!
    No harm in using a noisy pump, other than it could fail at any time and leave you scrambling.
    Although the lack of bonding is a potential concern.
