Results 1 to 12 of 12
Thread: Test results
    Mahomet, IL
    16
    Test results
    I just received my tf-100 kit and have run testing twice a week apart. Here are my results:
    Last week
    Chlorine 5
    Ph 7.5
    FC 11
    CC .5
    Calcium 250
    TA 160
    CYA 40
    Today
    Chlorine off the chart
    Ph 7.8
    FC 18.5
    CC 0
    Cal 275
    TA 200
    CYA 55
    Everything is creeping up. We did have 5.5 inches of rain last Saturday that nearly overflowed the pool. Was hard to keep up with pumping water out! It's been covered a few days this week and not used much. Temps haven't been very warm--75 ish. The water looks beautiful though. Any recommendations or is this all ok?
    37,000 gallon
    In ground
    Vinyl liner
    Sand filter
    Thanks!
    Oct 2013
    Chapin, SC
    1,141
    Re: Test results
    Testing for FC and pH isn't a weekly effort. You need to do it every day (at least do the OTO daily) you must be using solid chlorine for your cya to be increasing. If you continue that, you will end up with out of control cya.
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    38,300
    Re: Test results
    How are you chlorinating? I am going to guess a trichlor tablet feeder given the CYA creeping up. Your CYA is now just out of the recommended range, so you should only be using liquid chlorine going forward.
    How much Pool School have you read? Start with these:
    ABCs of Water Chemistry
    Recommended Pool Chemicals
    How to Chlorinate Your Pool
    Oct 2013
    Chapin, SC
    1,141
    Re: Test results
    Also, I just caught your 2 chlorine numbers 5 and 11 is the first one a cc number by chance?
    38,300
    Re: Test results
    Quote Originally Posted by timerguy View Post
    No, the 5 and "off the chart" is the OTO result.
    30,421
    Re: Test results
    Yeah, posting your increased results but not telling us how much and when you are actually adding doesn't help us much.
    I will say that there is nothing alarming about your numbers (and you did a nice job of making them legible and recording them) so you have no immediate issue but rather some trends that will need some control.
    How does your water look today? Is there any debris in your pool? would you describe it as sparkling or OK?
    Mahomet, IL
    16
    Re: Test results
    I have read all of the pool school, several times. I'm just in my 2nd year with this pool so it's taking me a while to get a good handle on it, and not sure I have yet. I am using the tablet feeder, 3" tabs.
    Thanks...I have been going through maybe 4-6 tablets total (3") per week. The water looks beautiful, sparkly and deep blue. I did vacuum some rusty looking stuff off the bottom, and some very light beige, almost white material. I am on a well, so when I do add water, it comes straight from our well. I can tell you that the water leaves rusty stains in the toilets and and tub in the house, so I know there's a high amount of iron in it.
    I do the quick chlorine and Ph tests with the small kit daily and so far they have been ok, with the chlorine being consistently high.
    38,300
    Re: Test results
    As I said before:
    You MUST stop the use of those tablets. Clearly the chlorinator is turned up too high since you FC keeps rising, but that also means you are increasing your CYA quickly too.
    Oct 2013
    Chapin, SC
    1,141
    Re: Test results
    Like I said before. You really should stop using the tabs. Mine looked pretty blue too until it took about 2 days to turn deep/cloudy (couldn't see the deep end drain) green! I sorta had the same conversations with the experts here and discovered my cya was >350. 44,000 gallons of water later it finally go down to 50.
    Mahomet, IL
    16
    Re: Test results
    Thanks so much! I am taking what's left of the tabs out and will continue to do the daily tests and weekly tests, using liquid instead when needed. Your help is very much appreciated. I felt like I got taken to the cleaners this spring by the local pool store...adding this $25 chemical, then that $30 chemical and nothing changed. The water was so cloudy until I started visiting this site and slammed according to your instructions. Funny, it cleared within a few days after I did that and has stayed clear since. But only after several hundreds of dollars spent at the pool store. Never again. One other question, the pool store sold Sparkle Up, which I used one scoop full diluted and it clogged my filter within minutes so bad that the pressure skyrocketed. I backwashed immediately, but some sand came out with it. Not a lot, maybe 1-2 cups. However, since then, when I do backwash, sand particles swirl around in the glass piece during the cycle. Is that ok?
    Becki
    Newbie with an in-ground, 37,000 gallon vinyl liner, sand filter.
    Oct 2013
    Chapin, SC
    1,141
    Re: Test results
    Please save your money and don't get pool stored again. I have no idea about that sparkle up, but the sand particles are probably going out with the backwash water. Backwash until the glass is clear--hope that doesn't take too long, but that just might get you down to a more reasonable 50.
    Mahomet, IL
    16
    Re: Test results
    Ok, thank you again!
    Becki
