Thread: Skimmer weir door keeps coming off
    May 2012
    Toronto, ON
    463
    My skimmer weir door (or flapper) keeps falling off. I am guessing it is because the round socket (or whatever) on the skimmer itself has because somewhat worn and doesn't hold the weir door as well as it used to. Do I need to replace the entire skimmer unit to fix this or are there other options?
    I don't know if these all work the same but my weir door snaps into a circular plastic holder. But it comes lose on pretty much a daily basis.
    Vinyl 18'x36' in-ground 100,000 L, Jandy Aquapure 1400 SWCG, Jandy Lite2 heater, StaRite System3 filter, Evac tube solar heating panels
    38,284
    Re: Skimmer weir door keeps coming off
    Does the part the weir snaps into disconnect from the skimmer?
    I remember one of mine had a thin piece of plastic that was screwed into the skimmer and the weir itself attached to that ... although that was a skimmer for a plaster pool, not sure if they are different.
    May 2012
    Toronto, ON
    463
    I don't recall seeing that but I will take a closer look when I get the chance. The skimmer is held into the side of the pool with about a dozen screws - you access these by pulling off the front facing of the skimmer which is just held in place by friction.
    38,284
    The the weir I had, the screw holding the door hinge was behind the door, so you have to stick your arm in from the lid and try to unscrew it.
    Like I said, not sure if yours is different though.
    May 2012
    Toronto, ON
    463
    FYI here is a photo that I took with my underwater camera - this is the side that seems to come off first. The Skimmer is labeled Equator. There doesn't appear to be any screws that allow you to remove part of the skimmer.
    38,284
    Hmmmm ... wonder if you could put a dab of epoxy on the top of the 2 prongs to better lock the weir in?
