Thread: caulking problems advice needed
    Apr 2014
    Pittsburg, KS
    17
    I have big gaps between the top of the pool tile and the coping - decking (not sure of the proper terminology). You can really only see it when standing in the pool. I can tell it was once filled with caulking but lots of it has disappeared and some mold has grown in on one side. I am attaching a picture (sorry it's upside down). This pool is only 2 years old, I am thinking it was not done right when it was installed. Is this something my husband and I can fix ourselves or do I need to call a pro? thank you!
    Here is one more picture (if photobucket worked right)
    [IMG]<iframe width="480" height="360" src="http://s44.photobucket.com/user/Leah_Smith_Wilbert/embed/slideshow/"></iframe>[/IMG]
    First year pool owner: 17,000 gal IG gunite, kidney shape approx 13' x 17'; 1 HP pump, Hayward sand filter, Intellichlor SWG, Polaris 280 robot, all run by EasyTouch. Using TF-100 test kit.
    ps0303's Avatar
    Jul 2011
    FL
    3,684
    Re: caulking problems advice needed
    Caulk is not the correct way to repair this. You would really want to use a grout to correctly fix this issue.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Apr 2014
    Pittsburg, KS
    17
    Do you have a recommendation on what type of grout to use? Thanks!
    mikespoolfl's Avatar
    Mar 2011
    Florida
    179
    The picture is upside down so this is where the tile attaches from the pool to the deck. I have cleaned out cracks like that and filled with white silicone, have some areas that I did 5 years ago and still looks good and holding. I tape it off first so I get good clean lines.
    Screen enclosed 17K gal 16x30 IG with Diamond Brite finish, elevated 4 jet spa with spill over, Twin dolphin fountain, Hayward Ecostar pump[ Pentair intelliflo VS, Filter Sta rite Posi-Flo PTM 100, Aqua Cal heat pump, Tiger Shark QC robotic cleaner.
    Stenner peristaltic pump model 45MPHP10, 15 gal storage tank. TF 100 with Speed Stir.
    30,403
    See if you can back away from the pool a bit and give us a better perspective. I am not sure what I am looking at. Not much but another foot or two should do it.
