Thread: Need quick answer RE adding chemicals to partially filled new pool
    Jun 2014
    Boston, MA
    58
    AGP installed yesterday. Only about 1/2 to 2/3 full right now. I need to shut off water to head to work. No chemicals have been added yet. Pool builder suggested adding shock and algicide. Should I add anything this morning b4 heading to work? I have bleach but wondering if I should use the shock that came with the pool? I don't know what is in the algicide?
    24'x 54" Round Sharkline Oceanic installed summer 2014,Hayward EC45 bump style 1.5hp DE filter (using cellulose),TF-100 test kit. First time Pool owner- thinking about SWG
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,007
    Re: Need quick answer RE adding chemicals to partially filled new pool
    In this type of instance, it would be ok to use a bag of shock. Bleach would be ok too though.
    Divin Dave,
    Jun 2014
    Boston, MA
    58
    Thanks! Added in some shock (not too much..probably about 8 oz) and that seemed to bring chlorine up to 3-5ppm range.
    Liquid, not solid
