Results 1 to 9 of 9
Thread: full automation
    dumbcluck's Avatar
    Aug 2013
    long beach
    674
    full automation
    if I wanted to control a Pentair vsp pump, a raypak heater, a Pentair ic40 swg, a Pentair 5g color light for both pool and spa and a solar panel would the easytouch syatem work or is the solar part not controlled by easytouch?
    confused by automation.
    -Jimbo- My pool was full of dirt and trees. Now it's full of water and children!
    20k gallon inground pool, 18" raised spa 7' round, 8 jets, 3" spa plumbing. Pentair intelliflo 3hp vsp, Easy touch 4 w/ ic 40, CCP 420 cartridge filter, Raypak 407a w/ cupro nickel, Screen logic 2, Pentair intelliph, spa side remote, Pentair 5g color lights pool and spa, TF-100 test kit with speed stir and Dolphin Oasis Z5
    Jul 2014
    Sacramento
    4
    Re: full automation
    All control systems are designed to include solar control.
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Re: full automation
    Yes an Easytouch will control everything you have listed, even solar.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    dumbcluck's Avatar
    Aug 2013
    long beach
    674
    Re: full automation
    awesome. good to know. so I just get the easytouch w/ic40 swg 4 control, pool and spa model and I can control everything I need? that's so cool. thanks
    Re: full automation
    The pool and spa panel comes with valve actuators, if you don't need them then the single body model will be cheaper. You want to specify the easy touch model with the included IC 40 as well, since it will come pre-wired for the salt cell including an integrated salt cell power supply.
    Additionally since you are getting the easy touch, I would get it with the IC60 model. It will only be $25 or so more, and the salt cell will last 50% longer since you will be running it at a lower power level. The easy touch allows finer percentage control of the SWG than you would have with a stand alone salt cell.
    Re: full automation
    dtlight, there are other differences between the pool&spa model and the single body model. You can not use a single body version of the controller to control both a pool and spa.
    Re: full automation
    I missed the spa part of the original post
    dumbcluck's Avatar
    Aug 2013
    long beach
    674
    Re: full automation
    wow. thanks. im pretty sure I wont need to control 8 things though. 4 should be enough and the 4 control doesn't have an ic60 option. 8 sounds like a lot I cant imagine needing it without any water features. also it looks like bumping up from 4 control ic40 to 8 control ic60 is closer to $300.
    dumbcluck's Avatar
    Aug 2013
    long beach
    674
    Re: full automation
    To incorporate solar into the easy touch, I seem to remember that I would need some extra parts. I'll have to search around to find that list unless anyone here knows that actually uses it.
    I am rough plumbed including the solar stub ups. I don't have any actual solar panels yet but probably won't be long after build is complete as I can't afford to pay pb installation prices. I will do panels myself but am wondering what I need to put in now during initial install so it can be as effortless as possible when the time comes. Should I install as if I had the panels and just cap stubs up by the roof they will sit on? Meaning fully connect on the equipment pad side, or is that a bad idea?
    Ok. Found the list.
    Solar valve. 263047
    2 way valve 263029
    Temp sensor 520272
    Actuator 263045
    Flovis flow meter
