Thread: Stained Finish
    Jul 2012
    Whidbey Island, WA
    398
    Stained Finish
    Do not hijack another's thread for info on your pool. Please, start a new thread as it causes confusion to the OP when discussing two pools in one thread. Casey~
    Quote Originally Posted by Casey View Post
    Looks like either organic staining or metal staining. You can check in 2 ways. If it's organic, a puck will lift the stain. If it's metal, a Vit C tablet will lift it.
    I have an old pool (replastered 20 years ago) and the plaster is discolored, especially just under the tile under the coping. Does not feel different than the rest of the pool Does not brush off. Can be rubbed off (slowly) with a pumice stone. I tried a puck and a vitamin C tablet and neither did much. If a puck and vitamin C do not do it, what are the possibilities?
    Thank you
    IG under fir trees and one cherry surrounded by grass built in 1979, 30k, plaster, old Sta-Rite HRPB30, 4.9 sq.ft, 20 GPM/sq.ft., but with new glass, new (in 2012) 1 HP WhisperFlo one speed, new (in 2013) Rainbow tab chlorinator attached at the top, old Maxi-Flo Heat Exchanger MF-260, Burnham V7 oil heater 245 MBH, new (in 2012) Compool to Easytouch, Taylor K-2005 and TF-100.
    Casey's Avatar
    SW PA
    10,461
    Re: Stained Finish
    If Vit C and a puck do not lift the stains, you should probably consider that it's time for a new plaster job/finish. If someone else has any suggestions, I'm sure they'll be along shortly to add to what I've just suggested.
    Jul 2012
    Whidbey Island, WA
    398
    Re: Stained Finish
    thank you
    will get some estimates
