Thread: Existing GFCI circuit, safe to remove GFCI on Intex cord?
    Mar 2013
    Oklahoma
    25
    I have an existing GFCI outlet outside the house for power to my Intex pump, SWCG, and lighting. Recently, the pump has been shutting off randomly and when resetting the corded GFCI the reset switch isn't catching. The pump will turn on, but if a fly were to land on the reset switch, it'll shut off again.
    My question is, since I have an existing GFCI circuit over to the pool, do I need to keep a GFCI on the cord to the pump? Any electricians here?
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Existing GFCI circuit, safe to remove GFCI on Intex cord?
    Part of your random shut-offs is the two GFCIs in the circuit. Yes, you can remove the GFCI from the pump cord, provided you replace it with a weather resistant end. Make sure the green wire goes to the green screw, the white wire to the silver screw, and the black wire to the brass screw. Before closing up the cord end, triple check that you don't have any stray strands of wire loose from the screws.
    Oct 2012
    Houston, TX
    186
    Yes, you actually should. 2 in series causes problems.
    I discovered that with mine and my electrician explained it to me.
    Intex UltraFrame 14'x48in - 3,900 gallons. Intex 1600 GPH combo Sand Filter/SWG Hard Plumbed w/Hayward skimmer, suction & return. Borates.
    And... 15k gallon kidney shaped gunite 1975 vintage. Hayward DE3620 filter + Hayward 750 pump.
    TF100 Test Kit | Pool School | Pool Math
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    Actually when I first purchased my sand filter (in Canada) the pump did not have a GFCI cord. The replacement pump (warranty) sent from the U.S. did.
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    Mar 2013
    Oklahoma
    25
    Good to know everyone. Thanks for the feedback.
