Thread: Does CYA from pucks show up on test right away?
    May 2014
    Houston, TX
    155
    I'm temporarily using trichlor pucks to increase my CYA while keeping the pool adequately chlorinated. Last weekend CYA was 25 (dead center between 20 and 30).
    My target is between between 40 and 50 (and when I hit that I'll go back to using bleach), so I've added 3 pounds of pucks in the past 3 days. The last pound is still in the inline chlorinator, and the first 2 pounds have already been dissolved.
    As of today, the CYA is still 25. Maybe closer to 30. So my question is even if the pucks had been dissolved a long time ago, does CYA still wait a week to show up on the test?
    IG gunite pool size: 12,500 gallons - includes spa with spillover, Polaris vacuum cleaner, Ultrapure Ozonator, inline tab chlorinator that I no longer use
    Filter: Hayward Swimclear Model #4030, 4-Cartridge Filters
    Pump: Century, 2 HP with a Hayward 6060 booster pump
    Date of build: March-April 2014 *NEW* : Test kit: TF-100
    38,521
    Re: Does CYA from pucks show up on test right away?
    I am pretty sure the CYA from trichlor and dichlor and liquid stabilizer should show up as soon as it is dissolved and circulated.
    The granular pure CYA even though it appears to be dissolved, may in fact not have completely been broken down which causes the delay.
    Jun 2014
    Central Florida
    36
    idk, but I found this posted elsewhere on this site by Bama Rambler.
    "Pucks come in different sizes. Common are 7 & 8 oz sizes. An 8 oz tablet will raise your FC by 2.2 ppm and your CYA by 1.3 ppm in a 25,000 gal pool."
    http://www.troublefreepool.com/threa...or-3-quot-puck
    So that should put you at 5.2 ppm per pound.
    It looks like you may have already done the calculation to reach your target (40). I thought I would post just in case.
    22,000 gallon in ground, gunite, Hayward pump 1.5 hp and 36sq DE filter. Pool installation date unknown, at least 10 years. Screened enclosure.
    May 2014
    Houston, TX
    155
    I actually have 1" tablets, rather than the jumbo size 3" pucks. I'm assuming 1 tablet is 1 ounce, or somewhere close to that. For each "pound", I just grab a heaping handful and dump them in the chlorinator. Because I'm approximating the amounts, I'm going for a target of 40 in case I overshoot it by a little.
    So I asked this question because I wasn't sure whether I should continue to add more pucks, or stop and use bleach then test CYA a few days later.
    Jun 2014
    860
    I have 1" spa tablets of 99% trichlor (Leslie brand) and they weigh 1/2 oz per tablet
    Mar 2007
    San Rafael, CA USA
    12,082
    3" tabs are from 6-8 ounces, usually 7-8; 1" tabs are 1/2 ounce.
