Results 1 to 15 of 15
Thread: I thought things were going so well...
    May 2014
    Monroe, Louisiana
    32
    But I believe I have an algae problem. Our pool looks pretty good in the shallow end but is greenish and getting cloudy in the deep. There is yellowish green "dust" along the surfaces. My first step was to begin brushing daily and set the pump to run continually.
    The CYA, according to a dilution test, is about 80. I don't think I was getting an accurate reading earlier and let the FC level get away from me, combined with super hot temps last week, etc.
    So, I just added 4gallons of bleach after brushing and vacuuming, and it started to rain. It's supposed to rain all weekend.
    Should I continue to keep adding bleach and SLAM in the rain? I don't want to waste my time and my bleach. LOL
    NE Louisiana
    25k gallon IG 16x30 vinyl liner pool
    Hayward Super Pump 1.5HP
    Intermatic timer, ~8hr/day
    Sand filter
    Re: I thought things were going so well...
    Rain won't interfere with SLAMing, though it will probably be less fun unless you are a dancing in the rain type
    38,475
    Your shock level is 31ppm of FC. 4 gallons (assuming 10%) only added 16ppm of FC to your pool ... barely half of what you need to get to shock level to start the ShockLevelAndMAINTAIN Process. Then you need to maintain the FC at 31ppm until you pass the 3 criteria to stop.
    Casey's Avatar
    SW PA
    10,453
    Have you thought about bringing that CYA down? You're not running a SWG and there is no reason to run such a high CYA.
    May 2014
    Monroe, Louisiana
    32
    After adding 6 gallons total, I'm up to 33FC (I forgot where I started, but it wasn't 0). It's raining pretty hard and getting dark, so I think I'll have to see where I am in the morning and go from there.
    Quote Originally Posted by Casey View Post
    Yes. I've not been positive on my testing technique though, thought I was around 60 before another big rain, therefore I assumed after the rain I'd be good. Evidently not. I should have done the dilution from the get go. Once this is all cleared up I'm going to check it again. BUUUT, in a few weeks we will be out of town for a week and I'm not sure what I'm going to do besides pucks in the auto feeder. :/
    NE Louisiana
    Sand filter
    Casey's Avatar
    SW PA
    10,453
    If you're going to use pucks in the auto feeder, I highly suggest you get the CYA down pronto!
    30,431
    Things are not going so well for you because you are not SLAMming the Pool. It seems like most folks who's slam is drawn out or failing is because they have taken shortcuts and processes that were a bit more convenient to do than what's written in the article.
    I'm sorry it sounds preachy, but if you really want the SLAM to perform as advertised you must follow that article to a T. No exceptions to the techniques. The affect of rain on a pool (or a SLAM) is virtually insignificant.
    May 2014
    Monroe, Louisiana
    32
    So, is the SLAM supposed to occur through the night? I never slammed before because I never had algae before. I'm a little confused.
    I'll continue with what I've done today...
    At 950 this morning, my FC was 21. I added 4 gallons and got it to 40 FC at noon. At 140, it's still 40. CC is zero.
    I'm going to check levels a few more times today and do the OCLT tonight- is that correct?
    NE Louisiana
    Sand filter
    30,431
    May 2014
    Monroe, Louisiana
    32
    I've read that, thanks. I like where it recommends asking questions in the forum because I'll supposedly get lots of help. When does that start?
    NE Louisiana
    Sand filter
    Mar 2011
    Houston, Texas
    413
    When does it start? It started yesterday. Six replies/answers in 24 hours is very helpful.
    As far as your post #8 about a SLAM continuing through the night, maintain means maintain. If you don't maintain the SLAM level of CL through the night you'll give algae a chance to overcome the CL.
    9,200 gal. Gunite Luna Quartz French Grey pool with spill over spa, two fountains on tanning ledge (rarely used)
    Pentair Whisperflo 2HP, Pentair CCP Cartridge 420 Sq. Ft., Polaris 280 with booster pump
    Pentair EasyTouch 4, RayPak LoNox 266k Natural Gas heater, Aqua Rite SWCG T Cell 9, Borates, TF-100 test kit
    May 2014
    Monroe, Louisiana
    32
    Quote Originally Posted by HouTex View Post
    Thank you. Reposting the SLAM link, which I have read repeatedly, isn't the most helpful thing I've see on here. And I was confused, because I've never seen anyone talk about burning the midnight oil through this process.
    NE Louisiana
    Sand filter
    38,475
    You test when you can for the SLAM process, at the start every 1-2 hours helps, but as the process goes on you will see that the FC does not drop as fast. That said, no one expects you to set an alarm every 2 hours to wake up or stay up all night.
    If you read the SLAM article is says "Test and adjust chlorine levels as frequently as practical, but not more than once per hour, and not less than twice a day." So you could get 12 hours sleep and still be following that instruction.
    Often when working members have to do this, it is good to start on the weekend, but during the week, they likely can only test and dose in the morning before work, right when you get home from work and then right before bed.
    Jun 2014
    860
    SLAM is a process. It takes a lot of work and careful planning to pull it off right. It requires patience that starts with not wanting instant results but with wanting to attack the problem with a good strategy. Unfortunately pool stores, pool builders and pool service companies along with chemical manufacturers have pushed the notion that healthy balanced pool water is just one bucket of "magic mix" away. They play on our need to find the immediate tactical fix as opposed to the long term strategic plan.
    So, the most important thing to do when the green monster shows up is to STOP. Take a deep BREATH. And develop a PLAN.
    When I decided to SLAM I decided to start on a Thursday night with wake ups every three hours (yes it was exhausting and my wife was mad at me) to check my FC levels. It was hard but by Sunday everyone was swimming in a sparkly clear pool and it's been a breeze to maintain ever since.
    Well worth the wait......
    Casey's Avatar
    SW PA
    10,453
    Quote Originally Posted by PoolsideinLA View Post
    I don't know why you feel you've gotten no help thus far.
    But since you do, here are a few articles that should help you understand pool maintenance a little more and prevent green and cloudy deep ends:
    ABC's of Pool Water Chemistry
    Recommended Pool Chemicals
    How to Chlorinate Your Pool
    Chlorine CYA Chart
