Thread: Aeration to RAISE PH?
    Jul 2014
    Atlanta GA
    2
    Split by moderator from HERE. Please do not hijack old threads and do ask questions in your own thread. Thanks, jblizzle
    I'm confused by the posts regarding getting the 'Ph back up.' Isn't the purpose of aeration to lower the TA? Some posters reference adding more acid to keep the Ph down during the process, and others reference trying to increase the Ph during aeration. So should Ph be kept low and TA measured until TA is down to the correct level and then borax added to raise the Ph again.
    Atlanta, 35k Salt Water, Gunite. Sand filter. Polaris Cleaner. Waterfall.
    38,284
    Re: Aeration to RAISE PH?
    Aeration ONLY raises the pH. Then when high acid can be added to lower the pH AND the TA. Repeat until TA is at desired level.
    See: Lower Total Alkalinity
    Waldog's Avatar
    May 2014
    Christmas, FL
    189
    Quote Originally Posted by atlantaguy View Post
    This thread doesn't really discuss Borax... but I too was confused when I first read the page that stated how to do this... I think the writer has a different "style". Anyways, the point is to LOWER TA with Muriatic Acid and that in turn lowers PH. To get the PH back up to specification (7.5 is my understanding) you aerate the water, and repeat if the TA is still to high.
    Got it?
    With relation to Borax, you want a TA of 70 to do so.
    Installed May 2014 - 16' x 48" Summer Escapes Pro Series Pool AG Vinyl (6,000 gal) - Intex 2650 Sand Filter - Christmas, FL
