Page 1 of 3 123 LastLast
Results 1 to 20 of 60
Thread: Hi, my name is Collee and I'm a pool maintenance neophyte.
    Jul 2014
    Long Island, NY
    22
    First and foremost, I have enjoyed reading all the invaluable information (although dizzying) on this site. I am amazed at how friendly, supportive and encouraging all the members are and I am excited to join the TFP club.
    I have a 16x36 IG vinyl pool with a loop loc cover which hasn't been open in 4yrs (i know, i know...feel free to shake your heads and yell..i deserve it). Pool was opened at the end of June and although the water was surprisingly clearer (light green and murky) than I thought it was going to be, the years of dirt and debris that accumulated on the bottom was quite discouraging. The coping was also detached in some areas. Shock and chlorine was added to clear water and coping was fixed. Pool was power vac 2x and I am proud to report that the water is now a clear(ish) and blue(ish).
    After reading many threads and articles on this site, I ordered the TF-100 and SpeedStir on Tuesday. However, for the time being I am forced to test water with the PS guys.
    Here are my numbers as of this morning
    FAC and TAC - 5 (could very well be higher but PS readings cap at 5)
    pH - 7.4
    TA - 90
    CYA - 30
    CH - 150
    TDS - 350
    Phos - 0
    I am going to throw my lil man (dolphin) in to hopefully clean the the leftover particles after power vac last night but pool will most likely need another power vac in the next couple of days.
    PS recommended 4lbs conditioner (leave filter running 24hrs) and in 48hrs, 15lbs of hardness. If power vac is to be done in next couple of days, do I bother adding the chemicals now or just wait until after power vac.
    In anticipation to convert to the TFPC method, I currently have the following chemicals on hand;
    (4) 121oz jugs of 8.25% bleach
    (2) 4lbs 12oz boxes of Borax
    (4) 4lb boxes of baking soda
    Leftover PS chemicals;
    8lbs conditioner
    45lb Hardness Plus
    Would love to hear your thoughts of what is really needed based on the above number readings. I am going to attempt to post pics so please be patient and stay tuned.
    16 x36 IG Vinyl ~ 21,000
    Filter - Hayward Pro Series HR Sand Filter Model # S244T
    Pump - Hayward RS 1,000 1HP
    Hayward Chlorine Feeder
    38,251
    Re: Hi, my name is Collee and I'm a pool maintenance neophyte.
    Welcome to TFP!!!
    Another victim of taking the (no longer used) BBB name too literal. Given you results, you may never need baking soda or borax.
    You do not need CH in a vinyl pool, so no point in adding that.
    No need to do anything until your TF-100 arrives and you can post up the test results. You will likely need to follow the ShockLevelAndMAINTAIN Process.
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Im not sure why you would need more "hardness" in a vinyl pool.... So I would probably skip that.
    If you don't need the borax or baking soda for they pool, they aren't wasted. They are great for laundry and cleaning.
    Jul 2014
    Long Island, NY
    22
    Thanks so much for the replies. The TA level was low the other day so I made good use of 3 of the BS boxes (i bought 7 in total). Before asking more questions (again thanks for your help and patience) I am going to attempt to post pics. Can only post 2 due to quota???
    #1 - first opened after 4yrs
    #2 - Mon - After 1 power vac, coping fixed
    Jul 2014
    Long Island, NY
    22
    This morn after 2hr power vac last
    nighthttp://s1383.photobucket.com/user/sh...tml?sort=3&o=2
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    You can use a photo hosting site like Photobucket to post pictures.
    May 2013
    Fort Lauderdale, FL
    423
    Congrats and welcome to the forum! We'll get you fixed in no time. You definitly will need to do the SLAM process. Plan on getting at least a dozen bottles of bleach, 2 ain't gonna cut it. The TF100 should be there soon, in the mean time, start getting the organic matter off the bottom. That stuff will eat your chlorine faster than you can get it in there. Run filter/pump 24/7. Read up on SLAM and OCLT.
    45'x12' 17k gal, IG plaster, Pool Pilot Nano+ SWG, 1/2hp Whisperflo pump, PAC-FAB TA-60D sand filter, Raypak 266 heater
    Pool School + Test Kit + Pool Math = Trouble Free Pool
    Jul 2014
    Long Island, NY
    22
    Thanks Zimm. I have been brushing on and off all day but the stains are still present. I assume (although one never should) that they are organic since the pool hasn't been opened in 4yrs.
    Any advice on how to remove? I know vitamin c is for metal stains but I might give it a shot.
    Casey's Avatar
    SW PA
    10,423
    Collee, Welcome to TFP
    You can get rid of the organic staining by running a slightly higher FC level than the normal for your CYA level. It will take time and weekly brushing. It took 4 years to stain the liner, it make take months to lift the stains. Be patient with the process.
    May I ask why you left the pool go for so long?
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    Beautiful pool and surrounding....I'd never cover that beauty! Show that thing off!
    Montgomery, AL
    27000 16 x 36 IG, Vinyl, Grecian, Hayward Sand filter, 1 HP Pentair whisperflo motor, Aqua Genie filter not by choice, no extra jets, Dolphin s300i robotic cleaner,Taylor K 2006 test kit, speed-stir which I couldn't live without!
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,410
    In to watch this one.
    You are doing great already-ordered a test kit already?? WOW!
    The color is looking better already!
    Kim
    Jul 2013
    Gilbert, Az
    116
    For not being taken care of for 4 years that pool looks great. Mine after one not so great summer and the winter looked like coffee... although mine doesnt get covered
    12k - free form - plaster- Nautilus fns48 DE filter- centurion 1hp (so quiet)- In floor cleaning system with Jandy Caretaker - TF-50 and 5 in 1 test kit, Phoenix, Az
    petrocomical's Avatar
    Apr 2013
    Baton Rouge Louisiana
    16
    X2 on the beautiful surrounding , Welcome to the forum and cant wait to see that beauty sparkle!
    30K IG vinyl kidney shaped, Pentair Tagelus 60, Hayward 1Hp superpump, Hayward booster pump
    May 2014
    Lewisberry, PA
    93
    I agree also....fabulous looking pool! Welcome to TFP! Try not to get ahead of yourself by dumping products in the pool until you can really understand what they will do. Reading through our Pool School several times will help tremendously! http://www.troublefreepool.com/content/
    You are going to love being able to test your water accurately and knowing what you need to do to your pool to keep it looking sparkly! You are getting great advice Collee, stay the course because I can't wait to see pics of your pool all cleaned up!
    16,000 gallon Oval Vinyl Liner Pool (new liner 2014)
    Custom built in 1999 to be half in-ground and half out (sloped yard) vermiculite bottom, laser sighted to Florida Room and Deck
    Purex Triton Model cc100 Cartridge Filter, 100 gpm flow rate, Penfair 1HP Pump
    TF-100 Test Kit
    Smykowski's Avatar
    Sep 2011
    3,065
    This is going to be a great thread. Please keep those pictures coming and let us know if you need help linking to a hosting site.
    And welcome to the forum!
    MBG75's Avatar
    Jun 2013
    Long Island
    184
    Welcome! Fellow Long Islander here.
    25k IG vinyl SWG Haywood 4830de 1.5hp TF-100
    Jul 2014
    Long Island, NY
    22
    Sorry for my absence and thanks so much for all the encouraging comments. I bought a jug of Vitamin C tabs and scrubbed the sides yesterday. WOW!!!! Unfortunately the Vitamin C test did nothing for the stains on the bottom. Going to lay a puck over a heavly stained area and test to see if it lifts.
    Woke up this morning to find that my TF100 arrived. WOO HOO!!! Be patient as this is going to be a learning curve for me. Stay tuned for numbers and lots of questions.
    Casey - pool wasn't opened for 4yrs because I traveled a lot (weeks at a time) to FL in the summers and well, yeah....it just wasn't opened. No real good excuse.
    Hey MBG75! Where are you located? I'm north shore, suffolk.
    MBG75's Avatar
    Jun 2013
    Long Island
    184
    North shore also. Mt Sinai
    Jul 2014
    Long Island, NY
    22
    I'm Northport
    Ok, here are results (i performed all) using the TF100
    CL 1
    Ph 7.2
    FC 2.5
    CC .25
    TC 2.75
    CYA - perfomed 2x, filled to 20 and could still see (although a but cloudy) black dot. Did a search on the forums and learned that test is to be performed in direct sunlight with back to sun. Ugh! Skies are cloudy now so I will wait until later to retest.
    TA 110
    CH 150
    I know I need to raise the FC and the Ph but seeking advice on goal numbers (5 and 7.6)????
    Thanks in advance for your help!
  20. Back To Top    #20
    MBG75's Avatar
    Jun 2013
    Long Island
    184
    I would adjust your ph up.
    Then proceed to SLAM the pool until it passes all 3 of the SLAM criteria.
    While that's going on. You can start to get your CYA up.
