Thread: How to Remove Metal Balls from Nature 2 Fusion
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,274
    I was asked before how I removed the metal from my Nature 2 Fusion mineral cartridge and I found an old one thought I would take some photos so that it might help others in a similar situation.
    The Nature 2 Fusion mineral pack adds copper and silver to your pool. Copper can stain your pool and turn hair green in large quantities. Also, if you switch to the TFP way, you won't need this mineral pack. Leaving the mineral pack in for long periods of time will cause rust to form and it will cause stains.
    Taking the metals out of the mineral pack took me about 15 minutes which included unscrewing it, getting tools from my garage, taking photos and putting part of the of the empty cartridge back into the Nature 2 Fusion.
    First, remove the mineral pack from the unit.
    Second, break the grey ring at the bottom of the mineral pack. This will make it easier to break apart the darker blue covering that holds the bag of minerals.
    Third, break apart the dark blue cover so that you can remove the bag of mineral balls. It is okay if you break part of the dark blue cover, just make sure that you don't break the grey top and the part of the blue cover that attached to the grey cover.
    Fourth, once apart, clean the part that is going back into the unit, as shown as the blue and grey piece at the top of the first photo. You don't want to introduce copper and metals back into the water
    I hope this tutorial helps someone else.
    Karen
    33K IG w spa plaster, Pentair 1HP Whisperflo, DE Filter, SWG CircuPool RJ-60, Dolphin Triton Plus, Raypak Dig 336K BTU, TF-100.
    Pool Math Chlorine / CYA Chart SLAM - Shock Level And Maintain
    2017 replaster/retile
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: How to Remove Metal Balls from Nature 2 Fusion
    Thanks for the post. I don;t have one but have always tried to visualize what others are talking about.
    Support the site
    38,251
    So when you buy a new "mineral pack" it includes the entire plastic container with the sack inside?
    Seems like a way to charge more money when they could just as easily made the plastic part serviceable and just sold the bag of metal.
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,274
    Yep, you buy the whole cartridge that is picture. I'm sure they don't want folks to see the rusted stains on the bag hence less people would buy their product.
    Karen
    pinguy's Avatar
    May 2015
    Pennsylvania
    516
    Thanks! I just popped mine open. No sack, but similar balls.
    Helpful Links: Pool Chemistry 101 - Recommended Levels - Recommended Chemicals - FC/CYA Chart - SLAM Instructions - Pool Math
    Test Kits:
    TF-100 - Taylor K2006 - SpeedStir Upgrade - Taylor K-1766 Salt Test
    My Pool:
    28k IG built May 2015 - Autopilot SWG - Pentair VS Pump/DE Filter/Heat Pump
