Thread: Skimmer filter baskets
    May 2014
    Lewisville, TX
    11
    Hello, all!
    I hope everyone is doing well. I have an odd question about the skimmer baskets on my IG pool. When the pump turns back on in the morning, it doesn't always pull the baskets back down into the seat. I tend to get a lot of debris into the pump skimmer basket this way. I was thinking of added a weight to the baskets, but wanted to see if anyone has done this before. I like to keep the pump on a medium low speed (2000 RPM). I find this provides the best balance between suction and energy efficiency. Any suggestions would be greatly appreciated. Thanks!
    e-Writer
    Lewisville, Texas
    13K IG plaster pool, Pentair Intelliflo Variable pump, Hayward SWG, Hayward Cartridge Filter, Hayward XL cleaning robot
    38,520
    Re: Skimmer filter baskets
    Welcome to TFP!!!
    I have always had a rock in my basket to prevent it from floating ... just make sure it is bigger than the hole in the bottom of the skimmer in case you drop it.
    May 2014
    Lewisville, TX
    11
    Thanks, Jason! I'll see what non-porous rocks are around the house.
    BTW, I just put a Hayward large capacity leaf catcher on my XL cleaning robot. Any tips/tricks on using it? The robot (we call him Rumper) seems to be moving a little slower, which I'm guessing is from the reduced suction. I changed the pump speeds slightly to compensate, but thought to ask if there's anything else I should know.
    Thanks a bunch!
    e-Writer
    Lewisville, Texas
    jcowart's Avatar
    Jun 2012
    Labelle, TX
    320
    I have the same problem when I use skimmer socks. Without one on it stays in place. Put a sock on and as soon as the pump kicks off the basket flips. I use a river rock but if you have money burning a hole in your pocket, they do sell weighted baskets.
    17500 gallon Doughboy AGP, Hayward DE filter, waiting for the 1.5hp DB pump to go out.
    Learn to take the advice here and be trouble free or use the pool store's advice. "You can't do both and get very far"
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Same problem here. The rock works great ! 👍
    Jeff
