Thread: Salt Water Test turns clumpy
    May 2012
    NC USA
    92
    I ordered the salt water test kit and when it arrived yesterday we immediately tested twice. The outcome has confused us. When we add the first drops(chromate) to the water sample as directed-it turned yellow like we read should happen. However, when we added the silver nitrate to the sample- it clumps up in the bottom and didn't change the color to salmon-ish. It just becomes more clumpy. Is this reaction common and supposed to happen? I wasn't sure how long to continue to add the SN drops after that clumping because I wasn't sure that was what was supposed to be happening and don't want to waste my drops.
    Thoughts? Thank you!
    I'll include today's test numbers in case it is relevant:
    CL-5
    PH-7.8
    FC- 5
    CC-0
    TC-5
    TA-80
    CH-90
    CYA-0 (we added stabilizer twice last week-in a sock- but it doesn't appear to be showing up)
    13 x 29 IG fiberglass pool-
    Waterways pump-Jandy Cartridge filter-Salt system- TF100 Test Kit-
    Casey's Avatar
    SW PA
    10,461
    Re: Salt Water Test turns clumpy
    Where did you purchase the salt kit from? Someone should be along soon to help you as I've never used one.
    May 2012
    NC USA
    92
    Hi Casey,
    Thank you for your note!
    I purchased the test kit through Dave S.- user name Duraleigh on TFP. I also bought my other pool test, the TF100 from him. I did ask him for info because of the seemingly odd results but he doesn't have a salt water pool and could not help me.
    If there is anyone who knows what this means or if it means anything, please share your thoughts with me.
    Thank you.
    Oct 2013
    Chapin, SC
    1,141
    A speed stir would help avoiding the clumps maybe? Mine turns granular settling after the test is over and I've turned my speed stir off.
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
