Thread: Pool ed
    May 2014
    Grand Junction, Colorado
    1
    Pool ed
    I want to use 6 % bleach to shock and to maintain the Chlorine for sanitation. How much bleach should I use for a 13500 gallon pool for shock and for maintenance. Thanks.
    13500 gal , IG vinyl, 1.0 HP Centurion pump motor, Hayward sand filter, model # lost (size is approx. 18 " dia x 3 ' hi), valve is possibly SP 71. I don't know the flow rate. The heater is a Teledyne-Laars and is rusting out and all controls are bad.
    Mar 2013
    Southlake, TX
    114
    Re: Pool ed
    Bookmark this site and use it frequently to tell you all you need to know about how much of what you need to add http://www.troublefreepool.com/calc.html
    19' x 37' Freeform IG; 25,500 gallons; max depth 8'6" with diving board; sun bench and swim out shelf. PebbleSheen Blue Granite Finish; Noble Tile--NVSA616 Peacock; Sandstone Retaining Wall; Oklahoma Flagstone Coping, Aggregate Deck; Small Water Feature w/ Moss Rock (70% flats and 30% boulders) Jandy Stealth 2HP Pump and CV460 Filter; AquaCal SQ156 Heat Pump/Chiller; Polaris 380 pressure cleaner w/ Halcyon boost pump.
