Thread: Pump Suction Fitting
    May 2014
    Cypress, TX
    8
    I am looking to install a Pentair Whisperflo WFDS-28 or -6. I see it has a 2 inch female pipe thread on the suction. What is the best practice for the male fitting? It seems best to go up to 2 1/2 inch on the suction pipe. Do they make a 2 inch MPT to 2 1/2 slip coupling?
    I think I saw on another thread a union fitting that might be nice. I have seen pros and cons to unions. The pro being flexibility to remove and the con being air leaks.
    Also, what is the best material for this fitting? just PVC?
    All comments are appreciated.
    18k gallon plaster with spa, Hayward 60 DE filter, Jandy Legacy heater, Polaris + PB40-60 booster, Pac Fab 700 2hp pump, stone waterfall 1hp pump, stone age timers
    Re: Pump Suction Fitting
    You want CPVC for several inches next to the pump. Pumps get hot sometimes, and CPVC is much more heat resistant. Typically you use a section of threaded CPVC, and then change the size up to 2 1/2" a couple of inches away from the pump.
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    Quote Originally Posted by Chris43 View Post
    I think I've seen as many reports of air leaks due to poor threaded connections and messed up slip connections (usually to flexPVC) than I've seen of poor union connections. It doesn't take much care to get a union connection rock solid, you almost have to work hard to cause a failure there. The pros outweighs the cons in my opinion.
    21K gal 16' x 40' in-ground pool built 1959, old school with Jacuzzi bronze pump, American Products 24" Sand Filter & Americana Multiport valve, Jandy Lite2 millivolt heater, Coverstar cover, and classic Kreepy Krauly.
    May 2014
    Cypress, TX
    8
    Thanks. Is 2" female pipe thread to 2 1/2 inch slip an available fitting? I see a 2" to 3" threaded bushing that costs $28 on Amazon.
    What fitting is normally used to go from 2" to 2 1/2"?
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    If you wanted to go CPVC, Lasco has a pricey adaptor (P/N 9838292) that is 2-1/2 SLIP on one side and 2" FPT on the other side. That would require you to use a CPVC nipple from the adaptor to the pump. If you used regular PVC there's a direct adaptor (P/N 436252) that would do the job.
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    I had lost my catalogue page link for Praher fittings when I originally posted to your question. Here's a link if you haven't already performed your plumbing parts selection. Praher has great unions meant for pumps. The 225-9061 seems to be just what you were looking for.
    http://www.prahervalves.com/pdf/union906.pdf
