Results 1 to 7 of 7
Thread: Where is my muriatic acid going
    Jul 2014
    Raleigh, NC
    59
    I am a new pool owner and I am trying to learn about a SWG system. My PH goes up about .2 each day. I am having to add muriatic acid about twice a week to keep it in range. What is happening to the acid?
    32,000 gallon plaster pool with spa. SWG
    Re: Where is my muriatic acid going
    It is effectively turning into water.
    You should lower your TA level to reduce the amount of PH drift you are experiencing. We recommend TA around 60 to 70 with a SWG.
    High TA is just like soda water, it effectively raises the dissolved CO2 level. The SWG causes aeration, with allows CO2 to escape. Since CO2 is an acid, that raises the PH.
    ranger_ric's Avatar
    May 2014
    Midland TX
    183
    Awesome Answer Jason..... Now, after 2 months of reading about this, I understand..
    Thanks
    17500 Gal Above Ground, 1.5HP Dynamo Pump, 250# Pentair Sand filter with ZeoLite. Diver Dave Cleaner. TFP test kit w/SpeedStir, 7 Grandaughters and 1 Grandson swimming every week WooooHooo!!
    Jul 2014
    Raleigh, NC
    59
    Thanks. Good explanation. My TA is currently 80. How do you lower the TA? Do they make a system that can add a acid drip into the pool like a chlorinator?
    Sep 2009
    Greentown, IN
    914
    When you add acid to lower the ph it also lowers the TA... aeration brings back up the ph but the TA stays at it's lower point. Doing this over time will lower your TA to where your ph shift is less and more manageable.
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    Jul 2012
    Georgia
    77
    Quote Originally Posted by JasonLion View Post
    You should lower your TA level to reduce the amount of PH drift you are experiencing. We recommend PH around 60 to 70 with a SWG.
    Jason, that is the post of the year!!
    I would love an elaborated "Pool School" that explains the WHY behind all of these recommendations, not just "TA of 60-80 for salt (THIS IS IMPORTANT)". Inquiring minds REALLY DO want to know WHY it is important!
    Those of us who are bad with cookbook recommendations can start to understand how getting lazy on a particular element is harming us.
    Loved it, want more of it.
    19k gal, STS1072R A.O. Smith C-Face Motor .75HP Full-Rated 2-Speed, Hayward Sand Filter
    LotusRacerX, the "why" information is around, but not nearly as well organized as the material in Pool School. A good place to start for "why" information is the Further Reading article in the Miscellaneous section of Pool School. Keep in mind that the "whys" tend to be a lot more complex and take more background to figure out.
