Results 1 to 8 of 8
Thread: skimmer not getting suction
    Jun 2014
    Monroe
    13
    Hi everyone,
    I just slammed my pool for the first time and the chlorine is finally maintaining the way it should! But, now, I am noticing that the skimmer is getting hardly any suction. It used to spiral with a lot of suction in the pool skimmer basket, but now it is so slight it hardly is working at all. The pool jets are still pumping out water into the pool just fine, though.
    Any thoughts on what the problem is here / how to fix it? Is this something I should call the pool company to handle or can I fix it easily on my own?
    Thanks!
    Katie
    40 x 19 oval in-ground pool, average 4.8ft deep located in Monroe, CT
    chlorine feeder attached
    38,516
    Re: skimmer not getting suction
    Did you change any valves? Have you cleaned the filter? What is your filter pressure? What is your clean filter pressure?
    Post pictures of your equipment and plumbing and add more useful information to your signature (pump and filter models, etc), please.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,058
    Has the filter pressure gone up?
    Have you vacuumed recently such that the pump basket is clogged or the impeller inside could have pine needles stuck inside it?
    30,432
    The "spiral" was never a good thing. What is your current psi when the filter is clean? What was it before ypu performed the SLAM?
    Jun 2014
    Monroe
    13
    Sorry for the delay in responding. I will try to post pics soon...my filter psi is 10, which is the same before the SLAM. Why was the spiral a bad thing?
    38,516
    Because it could result in air being pulled in through the skimmer.
    May 2009
    Topeka, KS
    81
    Not to highjack but, after replacing my skimmer line you should see mine "spiral". I had to go get a beer and watch it for a while. Was such an improvement from the "no spiral - barley any water moving". My spiral isn't enough that it would suck air, I don't think. I'll get another beer tonight!
    18x36 Buster Crab in ground, 3' shallow 8' deep, Hayward super pump, 300lb sand filter.
    38,516
    Quote Originally Posted by JasonK View Post
    You could always put a rock in the basket (bigger than the hole in the bottom of the skimmer please) to breakup the vortex if it becomes an issue.
