Results 1 to 10 of 10
Thread: My SWG
    daddycreswell's Avatar
    Jul 2013
    Lebanon TN
    130
    My SWG
    How do I tell when my SWG cell has kicked the bucket? I can't keep any FC in my pool this year, it's 5 years old. I see the bubbles when it's generating but I don't think it's doing the job right.
    16 x 32 18,000 gallon vinyl liner inground pool, Compupool SWG, 1.0HP Pentair pump, sand filter.
    38,537
    Re: My SWG
    Your SWG is the least of your worries right now ... focus on your other thread.
    If it is making bubbles, it is likely working, but can not keep up with the organics in the water and the possibly low CYA.
    Once you complete the SLAM and are maintaining the pool with bleach ... then start to work on the SWG.
    Jul 2013
    Lebanon TN
    130
    Re: My SWG
    Ok I have my water crystal clear and I'm loving it, just coming off the slam. So now I need to figure out if my SWG is doing its job. I know I'm going to lose chlorine during the day, haven't figured out what that loss is going to be yet, still testing it. So once I figure out daily FC loss how do I figure out if my SWG is doing its job or not? Thanks
    38,537
    Re: My SWG
    You can treat the output of the SWG, either at the wall out right after the cell and see if the FC is higher than the pool.
    Jul 2013
    Lebanon TN
    130
    Re: My SWG
    I don't have anyway to test it, it goes straight into the pool.
    38,537
    Re: My SWG
    Why can't you test it where it enters the pool?
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    Re: My SWG
    What Jason is saying is take a water sample at the pool return and test it. Then take a sample from an area that's distant from the return and test that. If the sample at the return tests higher than the other sample, then your SWG is generating chlorine.
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    Jul 2013
    Lebanon TN
    130
    Re: My SWG
    Quote Originally Posted by GreatCanadian View Post
    Got ya, thanks. I guess it would help if the SWG is generating.
    Jul 2013
    Lebanon TN
    130
    Re: My SWG
    Out of slam and pool is pretty as can be, tested this morning and my numbers are
    FC 6 taking it to 7
    pH 7.6
    TA 200
    CYA 60 taking it to 70
    What do I need to do to lower my TA? Thanks
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,025
    Re: My SWG
    Here is a link from Pool School.
    With your TA so high, you ph will be a bit unstable. Adding Muriatic Acid to lower PH will also lower your TA, so over a period of time, it will come down anyhow.
    The SWG provides quite of bit of aeration within the cell, which contributes to the PH rise.
    http://www.troublefreepool.com/conte...tal-alkalinity
    Divin Dave,
