Thread: Measuring pH minus vs dry acid.
    May 2014
    Hobbs, NM
    19
    Just a quick question....my husband came home with pH minus vs muratic Acid. Need to use up what he bought as I can't return it. In the calculator do the calculations for dry acid equal what I need of pH minus?
    By the way, been using the TFP method since opening our pool in April. Super simple and I get more complements on how sparkling clear our water is!
    +25 year old, 25,000 gal., IG, Gunite. New (2014) Hayward Super II 2hp pump and 310 sand filter, Rheem M266A heater.
    Re: Measuring pH minus vs dry acid.
    Yes, PH Minus contains dry acid.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I hope you explained the difference to him so it does not happen again
    Jun 2013
    East TN
    309
    I believe they equaled about the same when I figured it up. Dry Acid contains sulfates, which can attack concrete. Gunite = Concrete and Sand mixture.
    18,000 Gallon Aboveground. Sand Filter with 2HP 2 speed Pump.
    Quote Originally Posted by easttn View Post
    This is only an issue if you use huge amounts of dry acid.
