Results 1 to 13 of 13
Thread: tf-100 missing agents?
    Jul 2014
    Clermont Florida
    56
    I'm on the DPD test and it says add 5 drops of r-0001 and r-0002 and my kit has none
    epro05's Avatar
    Jun 2014
    Keller, Texas
    274
    Re: tf-100 missing agents?
    The TF100 has the FAS-DPD and OTO Chlorine tests. It doesn't have the DPD test as the FAS-DPD is more accurate and will test higher levels of Chlorine.
    27,500 gallon in ground gunite/plaster (1995). Attached Spa with fountain, spillway, and 2 lion heads streaming into the pool. Hayward pump and AO Smith UST1152 1.5 hp motor (single speed). Hayward 60 sq ft DE Filter (Model DE-6000). Kreepy Krauly cleaner.
    ThinkPad's Avatar
    Jul 2014
    East Coast
    227
    Triston, are these the instructions that came with the kit itself?
    I would recommend to watch this:
    http://www.youtube.com/watch?v=PHQG4tgQsFE
    Bobby (my pool)
    18,000 gallon in ground/white plaster
    Flotec pump/Aquatech MYB100 single cartridge filter - runs 6 hours/day in evening during summer
    Jul 2014
    Clermont Florida
    56
    Not the FAS-dpd, i was going of the extended kit directions on forum, and for DPD it says add 5 drops from R-001, and R-002, and my TF-100 dosent have them
    38,301
    The TF-100 does not include the DPD test ... that is found in the K-2005.
    Jul 2014
    Clermont Florida
    56
    Thank you very much! you made me very worried
    It seems the brown paper in the TF100 lacks some test information, ive seen other people put there TF-100 results on here and it contains much more than mine
    Jul 2014
    BH (Saratoga Area), NY
    62
    You should have gotten a checklist with the package, did you get this and cross check it? They have excellent customer service.
    38,301
    What brown paper?
    You can test FC, CC, pH, TA, CH, and CYA ... plus the OTO TC.
    Jul 2014
    Clermont Florida
    56
    I have everything, used the checklist
    And theres a Beige paper with like all this information about weekly tests and such
    Im going to test my pool later just needed a list of everything i can test, got kinda overwhelming earlier, i got as far the FAS-DPD but **** i was on bout my 6th scoop when i just said ya know im gonna cool off and do it later. Seems as everything is in order Thank you guys im almost sure ill need more help though, this site is a life saver
    Oct 2013
    Chapin, SC
    1,141
    6th??? My k-2006 only takes 2 and my sample is deep pink.
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    38,301
    Yeah, you should never need more the 2 scoops of powder (and only the 2nd if you are at high 20+ FC levels). If the water does not turn pink, then you likely have zero FC which can be verified with the OTO test.
    Jul 2014
    Clermont Florida
    56
    dont ask, i have a very hard time with directions and that such, are you familiar with Attention Defecit Hyperactivity Disorder? its much more than that, makes it very hard for me to apply sustained concentrated mental effort
    Isaac-1's Avatar
    SW Louisiana
    6,711
    If you have not yet watched them I suggest the you tube videos
    https://www.youtube.com/watch?v=PHQG4tgQsFE
    http://https://www.youtube.com/chann...9Y_YYNAeLtUr1g
