Results 1 to 9 of 9
Thread: What is Sequestrant?
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    I hear others talking about adding this to their pool, should I also be adding this, if so what would I look for in buying it? Thanks
    13,000 Gal Pool & Spa
    Jandy Automation /w IAqualink
    Autopilot SWG
    Jandy 2.0 HP VSP, Filter Cartridge
    Taylor (FAS-DPD K-2600, Pool Surface: Plaster
    Re: What is Sequestrant?
    Sequestrant is any of several chemicals that bind to metal ions dissolved in the water and prevent them from depositing as stains. All sequestrants break down slowly over time, so you need to add more at regular intervals to replace the portion that has broken down.
    There is no point in using sequestrants day to day unless you know you have metal problems. The only time sequestrant is worth using as a general protection is when fresh plaster is applied, as metal stains on brand new plaster can never be removed.
    Sequestrants based on HEDP, phosphonic acid, or phosphonic acid derivatives are the most effective. ProTeam's Metal Magic and Jack's Magic The Pink Stuff (regular), The Blue Stuff (fresh plaster), and The Purple Stuff (salt) are some of the top sequestrants. You can also find many other brands with similar active ingredients, some of which are noticeably less expensive.
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    If I had used a copper base algaecide, will it eventually over time leave the water? Thank you
    Autopilot SWG
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    No. Metals stay put. The only way to remove them is by replacing water and diluting it enough that it doesn't do anything.
    Think of metals as chocolate. Sequestrant is the hard candy shell on an m&m. The chocolate is still in the bag, it just isn;t visible and won;t make a mess but it's still there.
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    OK so everyday or so I keep draining rain water from my pool, it will eventually get weaker...as the pool keeps getting full again.
    Autopilot SWG
    38,369
    Yes, because you are removing water from the pool.
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    OK I have removed a few copper spots with vitamin c tablets. I haven't seen anymore so far, I did order AA just in case.
    Autopilot SWG
    Richard320's Avatar
    Jan 2010
    19,037
    Quote Originally Posted by boston62 View Post
    Sent from my SCH-I535 using Tapatalk
    Yep. But very slowly. Using my own pool as an example, I know my average depth is 60". So replacing 3" of water lowers whatever Calcium, CYA, or metals are in the water by 5%.
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    OK great. Thank you
    Autopilot SWG
