Thread: Teledyne Laars - to replace?
    May 2011
    Los Angeles, CA
    228
    I am planning a revamp on the pool equipment. Plans are to convert to SWG, install acid injection system, replace diverter valves and maybe the teledyne laars one series 400,000 BTU heater also. How effecient is this series? should i replace it with something more modern? if yes, can someone please advise on which heater to buy? I am looking for most reliability and efficiency to keep heating costs low. I will mostly be using the heater to heat up the spa rather than the pool.
    Thanks!
    Suley, West Hills, CA
    IG 23000 Gallons with IG Spa Gunite plaster, Pentair Intelliflo VS 3HP, Pentair Clean & Clear Plus 420 Cartridge filter, Teledyne Laars One series 400,000 BTU Nat Gas Heater, Hayward Max Flo 1HP Single Speed Spa pump, Noisy Spa blower, Dolphin Deluxe 4 robotic vacuum.
    ps0303's Avatar
    Jul 2011
    FL
    3,708
    Re: Teledyne Laars - to replace?
    Raypak/Rheem seem to get the best reviews on here.
    Paul
    http://www.gastekservice.com If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Check out some videos on my YouTube channel - http://www.youtube.com/c/Gastekservices
    May 2011
    Los Angeles, CA
    228
    Thanks!
