Thread: Why is FC falling and pH rising with no CC or change in CYA
    May 2014
    Van Buren, AR
    7
    26400gal vinyl
    CYA 30
    FC 3.5
    CC 0
    TA 190
    pH 7.4
    I thought I had mustard algae and slammed. But my FC wouldn't hold and CC continued to read at 0. My pH goes up every day, I've had it at 8 and higher for the last 3 days, add MA to drop it and it goes back up. And, I did have consistent CYA of 50 and we've been hit with some rain. That's when I noticed what I thought was mustard algae so I checked CYA and it was 0! So I got CYA up and started slamming. But something's not right. If it were algae there would be concentrated chlorine killing it, but there's not. Please help
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Why is FC falling and pH rising with no CC or change in CYA
    First, you have to keep all your post together in one thread. You have started or posted comments/questions on at least 3 different threads that I see. It is extremely difficult to keep up with what you are doing when it is all over the board (no pun intended). You came here for help and the folks here do want to help. But, they need to see the whole picture.
    Now, ignore pH during a SLAM. pH testing reads high when FC is above 10.
    A SLAM is a marathon, not a sprint. You will continually add chlorine, it will keep going down as you oxidize organics in the water.
    Support the site
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by aek511 View Post
    26400gal vinyl
    CYA 30
    FC 3.5
    CC 0
    TA 190
    pH 7.4
    You need to finish the SLAM. Don't stop until you meet the three criteria that determine you are done. See red lines in my sig.
    Are you adding enough bleach/liquid chlorine to reach SLAM FC level of 12?
    If yes, how often are you testing/adding?
    Are you brushing every nook and cranny daily?
    It would be helpful if you add your pool and equipment specs in your sig.
    yes, as Tim mention mentioned, ignore the pH until you finish the SLAM.
    You're done SLAMing when:
    May 2014
    Van Buren, AR
    7
    Sorry about being everywhere. The other comments were when I first opened the pool and i got it under control. So I started a new thread because I'm not 100% sure I am dealing with mustard algae.
    Yes, I'm slamming to 12 and checking and adding liquid bleach as needed. However, FC won't stay at 12 but CC still reads at 0 so where is it going? And I am brushing like a madman. That's why I was wondering if there's something else going on. And get this, my CYA was 30 this morning. It's now less than that this evening.
    May 2014
    Current: Singapore Previous: Clayton, Victoria, Australia
    584
    According to this thread, you are using a K-2006 to test.
    The CYA test is dependent on the lighting, it is recommended to do the test in bright indirect sunlight.
    FC won't stay at 12 because something is consuming it, not all organics cause an increase in CC.
    Also, with regards to this post, I suspect 7.85 is "% available chlorine", you should use "% sodium hypochlorite" (8.25%) for calculations in PoolMath.
