Thread: Which way to point the returns?
    Jun 2014
    Markham/Ontario
    52
    Here is a real new pool owner question.
    I have two returns in my pool. One in the deep end and one in the shallow end. They are diagonally across the pool from each other.
    Which direction should the returns be pointing? Towards the bottom of the pool? Towards the surface of the water with just a ripple on the surface?
    15K Gallons, IG, Vinyl, 1HP Single Speed Pump, Sand, SWG, NG Heater + Solar Panels
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: Which way to point the returns?
    You'll just have to experiment and see what gives you the best circulation.
    Orlando, FL
    13
    I aim mine to create maximum clockwise rotation- just a slight ripple on the surface (this was recommended by pool refinisher, too). If all your chlorine comes from tri-chlor tablets on a surface floater, you might aim down to increase mixing.
    George
    18K Pebble Tec pool & spa, Jandy Jep2.0 VS ePump, Jandy CS250 cartridge filter, Sta Rite Maxi Therm 333 propane heater, Hayward Aqua Rite SWG, Heliocol solar panels, remote fill/drain—All controlled by AquaLink RS8 One Touch
    Mar 2014
    Las Vegas
    288
    Experimentation is about the only thing I can recommend. I tossed a dozen practice golf balls in the pool, timed how long it too them to get into the skimmer. Then I'd adjust the returns and repeat the test. After multiple tests, I set the returns to the setting with the fastest time is where I ended up setting them.
    Almost forgot. Do this on a day with no wind.
    12000 Gallon IG Plaster built 2/15/2014. Jandy 340 sg ft 127 gpm filter, Jandy 1 HP stealth pump. Circupool RJ-45 SWG (overkill). TF-100 with Speed Stir.
