Results 1 to 7 of 7
Thread: Test Results
    Jun 2014
    Glendora, CA
    61
    Test Results
    Hello,
    I just stopped by the pool store and have them test my sample . I already bough the test kit TF-100 Test Kit (still in the box) and will compare it tonight against the store.
    So far from the pool store:
    Chlorine: 3.0
    P.H.: 7.8
    Alkalinity: 190 (he wrote on same line 146.7 CYA)
    Conditioner: 130
    Phosphate: 200
    Pool store recommended 2 quarts of acid (Muriatic Acid), pouring one quart per day. I will post my test result tonight from the kit I bought
    TT
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Test Results
    Ok we'll wait for the real test results. 😎
    Jeff
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Re: Test Results
    CYA to the nearest ppb. Impressive.
    Not.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    30,426
    Re: Test Results
    trackstar,
    I want to make sure you get the gist of the replies to this point. In a nutshell, you would probably better served if you ignored completely the pool store results.
    The whole point of your own testing is that it gives you the precision and repeatability to make good decisions on what, if any, changes you need to make to your pool.
    Comparing results will only confuse you and even confuse any actions you may decide to take
    Mar 2014
    Las Vegas
    288
    Re: Test Results
    ^^^ What he said.
    I've taken 3 samples taken at the same time to 3 stores within an hour, got 3 completely different sets of results, and 3 totally different expensive recommended purchases.
    With the TF-100 I can test 3 samples and get exactly the same results.
    Which would you trust?
    12000 Gallon IG Plaster built 2/15/2014. Jandy 340 sg ft 127 gpm filter, Jandy 1 HP stealth pump. Circupool RJ-45 SWG (overkill). TF-100 with Speed Stir.
    Jun 2014
    Glendora, CA
    61
    Re: Test Results
    I haven't had a chance to test it yet. The house we bought with the pool still is a distance away from my old house and without internet there its hard to live . If I store the water (sample for testing) for over a day, would the test be legitimate?
    I will post a new thread with results as it is better not to confuse with the pool results.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Re: Test Results
    Quote Originally Posted by trackstar2000 View Post
    The sample will be no good. CYA and CH will probably be accurate, and maybe TA, but pH will change with all the handling and temperature changes, and FC disappears with time no matter what.
