Thread: Need help my deck jet sunk
    May 2013
    Hartsville South Carolina
    46
    Hey all, one of my 4 deck jets sunk down. If I run the jets this one is down too far and the stream of water hits the edge of concrete. Do you think if I tie some thin rope around the center of it I can pull it back into place? Also do you think the plumbing is messed up? Thank you for help.
    Ryan
    23k gal, IG, vinyl, Pentair sand filter, 1 hp single speed pump, pool pilot digital swg, Hayward sharkvac. Built May 2013
    Killer95Stang's Avatar
    Sunny SoCal
    592
    Re: Need help my deck jet sunk
    get like a piece of wire or chain.. with some type of rod at the end to make a "T", that can be slid into the deck jet hole. The pull up on it. Maybe get some kind of epoxy on the sides, to hold it back in place.
    Pool done!! (backyard = work in progress) 32' x 19' inground freeform with 7' spa, baja step w/ (2) bubblers, stonescapes mini pebble finish, rock waterfall feature, 12" raised bond beam, Intelliflo VS, Whisperflo feature pump, (3) 5G Color LED's, FNS + DE 60, 400K Master Temp, Easytouch 8 w/ remote, Intellichlor IC40, Vision Classic Ceramic Kamado smoker, Margaritaville DM1000!!! Party Coming Soon!!
    TF-100 Test Kit w/ Speedstir
    38,479
    Clearly there is nothing below the plumbing holding the jet in place ... so that is not good.
    May 2013
    46
    JBlizzle, I hear ya on that. Do you think the back fill settled in that spot and the plumbing dropped?
    38,479
    Hopefully that is all that happened and not a water leak shooting out and eroding the dirt under the plumbing.
    Although I am not sure how it could settle just under the plumbing, unless the installers did nothing to compact it.
    May 2013
    46
    Well, now I'm not sure if it sunk or they just did a terrible job at install. I've never adjusted the direction of them until this week. That's when I found I was very limited on adjusting it due to it being so low. I got a slip knot around the nozzle base and couldn't get it to budge. Not even a little wiggle. I guess I will see what PB has to say. Thanks
