Thread: Skimmer Question
    drestes's Avatar
    Sep 2013
    Rome, GA
    34
    Skimmer Question
    I have noticed that the skimmer suction isn't very powerful. Is there a way to divert from the main drain and increase the skimmer action? Here is a photo of how it is set up now. How should I position the handle to divert more suction to the skimmer and away from the main drain. Thanks in advance for any help!
    18 x 36 vinyl liner IG pool, grecian shape, ~27k gal
    1.5 hp Hayward Super Pump, Hayward DE3620 Filter
    Hayward Aqua Rite Electronic SWG, Dolphin Triton PS robot
    TF-100 test kit with SpeedStir
    38,254
    Re: Skimmer Question
    What does the valve say opposite the handle? Closed?
    Right now you have the drain and skimmer fully open. Turn the handle 180 degrees and the drain will be closed with all suction through the skimmer. Unfortunately, this valve was not installed in the ideal orientation with the pipe to the pump in the middle port which allows better mixing.
    drestes's Avatar
    Sep 2013
    Rome, GA
    34
    Yes, "Closed" is opposite the handle.
    So if there isn't a way to split is 70/30 or so, is it best to leave the drain closed most of the time?
    Thanks!
    38,254
    Put the handle at about the 2 o'clock to 2:30 position and that will have the floor mostly closed and hopefully the skimmer mostly open.
    drestes's Avatar
    Sep 2013
    Rome, GA
    34
    I'll give that a try. Thanks again!
