Results 1 to 10 of 10
Thread: Salt level in pool!
    May 2012
    Oconee, Georgia
    82
    Salt level in pool!
    I have a pentair IC40 my pool was built in October so it isn't even a year old. I have the Easy Touch system decided I better clean the cell today. So I put the cap on it and poured the mixture in the cell didn't foam at all so I just washed it back out and put it back on. Pluged it up and turned to the pump on for about an hr to make sure it wasn't going to leak. My salt level was 3600 before I cleaned the cell now it says the level is 4300. Is this a probleam? I need to get a good test kit for salt what do you recommend?
    18'x36' inground vinyl liner.Pentair Sand Filter SD-60, Pentair EastTouch IC40 Salt Gen.
    Pentair Legend Cleaner. Pentair SuperFlo 1 hp pump. Color LED pool light.
    Taylor K-2006 (FAS-DPD) w/ SpeedStir. Pool Built October 2013.
    38,371
    Re: Salt level in pool!
    Was there a sign of scaling? If not there would not have been any reason to clean it.
    But, sense the salt reading went up, the cleaning obviously did something. As long as the SWG is not complaining about high salt, you are fine.
    I prefer the Taylor drop-based salt test over the salt strips.
    May 2012
    Oconee, Georgia
    82
    There was just a little bit of buildup on the fins not a lot. I bought the kit to clean it this spring and though it wouldn't hurt to clean it. Didn't bubble much at all.
    Killer95Stang's Avatar
    Sunny SoCal
    592
    I think I had the same issue... my cell seems to read higher after its initial cleaning... I use Taylor drop test to verify where the salt really is and I don't worry about the cell reading since its within usable range.
    Pool done!! (backyard = work in progress) 32' x 19' inground freeform with 7' spa, baja step w/ (2) bubblers, stonescapes mini pebble finish, rock waterfall feature, 12" raised bond beam, Intelliflo VS, Whisperflo feature pump, (3) 5G Color LED's, FNS + DE 60, 400K Master Temp, Easytouch 8 w/ remote, Intellichlor IC40, Vision Classic Ceramic Kamado smoker, Margaritaville DM1000!!! Party Coming Soon!!
    TF-100 Test Kit w/ Speedstir
    May 2012
    Oconee, Georgia
    82
    What are the reagents for the Taylor drop-Based system I should be able to just by the reagents and use them with my speed stir or is it just as cheap to buy the kit?
    May 2012
    Oconee, Georgia
    82
    38,371
    The kit is just 2 reagents (do not know the numbers off hand) and another vial (which I use with the SpeedStir as there is a white build-up in it from testing).
    May 2012
    Oconee, Georgia
    82
    The kit is $22.87 Amazon Prime so free 2 day shipping
    Thanks for the help guys. Tell ya how I clean my speed stir vial I just Chlorox brand wipes after every use and it stays crystal clear!
    38,371
    We are working on having uniform profiles for all members. Please add your location (City, State or City, Country) to your profile as described HERE as it will help us help you in the future.
    May 2012
    Oconee, Georgia
    82
    K I updated it I guess
