Thread: Easy touch questions! thanks!!
    Columbus Ohio
    178
    Hi all,
    Hope someone can help, I currently have the easytouch 4 with a wireless remote. I am looking to change over to the screen logic2 but didn't know if the wireless adapter that the remote works off of is the same that is needed for the screen logic (The antenna thing that is attatched to the side of the house and connected to the motherboard)? If that even makes sense. Our remote stopped working, and 500 bucks to replace the remote or 400 to turn it into screen logic seems more do able.
    Thanks so much!
    Clayton
    Purposed new pool at home being built- 20x40 vinyl pool, 20ft vinyl covered steps, Automatic cover, 6 ft sheer decent, 4 lighted deck jets, lime stone coping, easy touch, heat pump, SPA- 8x8 fiberglass shell, limestone steps surrounding
    previous home- 16 x 32 IG Vinyl- Install- Mid June 2011. 3ft Shallow 8ft Deep/ Totally Hayward 1HP pump/ 250 pound Sand/ AquaPro800 Heat pump/ Blue Hampton Liner/ 2 Intellibrite LED Lights/ Polaris 360/ 4 Deckjet II's/ 3ft concrete Apron/ 800 sq ft Paver Patio
    Re: Easy touch questions! thanks!!
    The screen logic package includes a protocol adapter that needs to be connected to the main control box either with a wire or wirelessly. If you want to connect it wirelessly, you existing antenna "thing" will work.
