Thread: Green Cloudy pool
    Jul 2014
    Portland OR
    1
    Green Cloudy pool
    I am this close (less than an inch) to just draining the pool into the street!
    We have a 12 x 24 rectangular INTEX above ground pool. The water was clear when I pulled back the cover, but I went back to Wisconsin for a little over a week and didn't replace the cover. We have 5 huge cherry trees in the yard and they splatted into the pool.
    The water was green with slimy cherries when I returned. I scooped the cherries out and used Green to Blue but absolutely nothing happened to clear up the green.
    I've backwashed and replace 3000 of water; used 5# of shock and Green to Blue 3 more times and I still have green water only now it's opaque.
    Next I bought a "Pool Critter" and put that into the pool. Well, that was a moot point because I couldn't even see if it was on the bottom so I hauled it back out.
    Last night I bought floc and threw that into the pool. This morning the water is still opaque and green. How long should I wait to see if this is even working?
    OR: Should I drain the pool and start over?
    38,475
    Re: Green Cloudy pool
    Welcome to TFP!!!
    First I suggest you read ABCs of Water Chemistry so we are talking the same language.
    To clear a green pool you do not need shocks and flocs and algaecides ... you need chlorine. Just follow the ShockLevelAndMAINTAIN Process using one of the Recommended Test Kits with the required FAS-DPD chlorine test.
    OR
    Drain and start over and learn from Pool School how to properly maintain the chemistry.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Green Cloudy pool
    Welcome to TFP !
    If you have the option to dump it and start over that may be the way to go.
    Either route you take, take a look at these articles to help you understand your water chemistry and it's needs. You will also need a good test kit like was suggested.
    How To Chlorinate Your Pool
    ABC'S Of Pool Water Chemistry
    Any questions you have don't hesitate to ask. 😎
    Jeff
    Casey's Avatar
    SW PA
    10,457
    Welcome to TFP. You can't go wrong by reading the ABC's of Pool Water chemistry and ordering a good reliable test kit that you will use every day.
