Results 1 to 15 of 15
Thread: pics of pool
    Apr 2014
    FOUR cORNERS
    111
    pics of pool
    i really hope this works, technoligy has passed me by
    16 'x 48" Metal Frame Intex 5065 gallons, 14 Inch sand filter,Hayward Skimmer SP1091LX Dynaskim, Test Kit TF-100
    ThinkPad's Avatar
    Jul 2014
    East Coast
    227
    Re: pics of pool
    I like the exterior on the pool! Don't worry, your post worked.
    Bobby (my pool)
    18,000 gallon in ground/white plaster
    Flotec pump/Aquatech MYB100 single cartridge filter - runs 6 hours/day in evening during summer
    Apr 2014
    FOUR cORNERS
    111
    part of hard plumb
    this pic is only of new Hayward skimmer, using 2 suctions, close skimmer when grandkids are playing, turn sand filter to circulate and run fountain. will post more pics. I'm slowly learning
    38,235
    Re: part of hard plumb
    FYI, the use of non-pressure rated DWV fitting like you used near the green strap is not recommended. You should ideally use schedule 40 PVC.
    At least this is on the suction lines, but the fittings you used do not allow as much area for the solvent act on.
    Also, please keep these related posts together. I have merged these.
    Apr 2014
    FOUR cORNERS
    111
    Re: pics of pool
    ok thanks for the info will change in fall fittings in fall, just learning to post, please forgive me
    38,235
    Re: pics of pool
    They are installed at this point, so I might leave them (since they are not actually under any pressure), but keep an eye on any leaks developing.
    Jun 2013
    Manitoba, Canada
    153
    Re: pics of pool
    There is very little pressure on those pipes, you will be fine just leaving them.
    May 2014
    Nevada, TX
    238
    Re: pics of pool
    Looks great!!! Hope you love tub as much as we love ours!
    27'x54" Sharkline Venture
    Hayward X-Stream Full-Flo 150 sq. ft. Cartridge Filter
    Matrix 1.5HP Dual Speed Pump
    Hayward Aqua Critter Automatic Above Ground Swimming Pool Vacuum Cleaner AR500Y
    TF-100 test kit
    Apr 2014
    FOUR cORNERS
    111
    Re: pics of pool
    we do had to replace tub last year,new tub from Intex $148.00 the old blue one started leaking at seams, metal frame and parts are 6 years old this year, took down every year and put away in closet. Liner only, This year we will leave it up after setting post on blocks and being leveled correctly. each year level so so and take down. I did vacuum last night cause pic I took showed the debrie at bottom of pool. Again this site is amazing thanks for all your knowledge and words of encouragement. FYI we do have a SWG could never get it to work right, next year it will be working, now I know!!!
    Jun 2014
    Villa Rica, Georgia
    15
    Re: pics of pool
    Wow nice work! The ladder, is that something you put together or is it off the shelf? Any more info would be much appreciated!
    Apr 2014
    FOUR cORNERS
    111
    Re: pics of pool
    Actually, most people put the stairs in pool, ladder on outside of pool, ladder is a safety ladder, it folds up, we just zip tied it down inside of pool, we have no children at home, but the grand kids come over and play in it so we have no worries of any one just getting in pool,(besides we only have 1 left who needs to learn how to swim and he is currently doing that) ladder and stairs were purchased as separate items but can be assembled together. many of your on line pool stores have them, i can't remember cause we bought when we first got our pool 6 years ago.
    jmcdtucson's Avatar
    Jun 2014
    317
    Re: pics of pool
    Nicely done. I keep leaning toward using river rock for the area around the pool just like you've done. How do you like it?
    Intex 12'x24'x52"
    8,403 gallons
    Intex SF60110 2450 GPH Sand Filter
    Intex CS8110 SWG
    Aquabot AJET121I Pool Rover S20-40
    Apr 2014
    FOUR cORNERS
    111
    Re: pics of pool
    we love it, love the price (did I mention it's free out here), every where you look there's river rock
    May 2014
    Glenshaw,PA
    19
    Re: pics of pool
    Looks very nice!
    Susan😎
    Swim N Play Yorkshire 15'x48" round AGP
    Pentair Clean and Clear 75 sq ft Cartridge filter and 1 hp Optiflo pump
    Hayward Aquabug cleaner🐞 and Taylor K-2006 test kit
    Casey's Avatar
    SW PA
    10,418
    Re: pics of pool
    I really like this!
