Thread: Error Code OH in Hot Tub
    Jul 2014
    High Point NC
    1
    Angry Error Code OH in Hot Tub
    I just moved into a new home and it came with a Dreammaker Hot tub I had a guy out to check it and get it started and I used it for the first time and I got an error code OH and it got hot and I cant get the temp to go down what can I do to fix the problem without calling someone that's gonna cost for another service call?
    38,290
    Re: Error Code OH in Hot Tub
    Welcome to TFP!!!
    I deleted your other thread. Please do not double post. I have no idea how to help you so hopefully someone else will chime in.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    They have all the manuals on line - Google is your friend
    From the manual:OH= Overheat The spa has shut down. One of the sensors has detected that the spa water is 43C (110F).
    Warning Notice: DO NOT ENTER THE WATER. Remove the spa cover and allow water to cool. At 41C (107F), the spa should automatically reset. If spa does not reset, shut off the power to the spa and call your dealer or service organization.
    From my experience in repairing mine, for some reason water has stopped flowing across the heater. If you are comfortable troubleshooting, working with plumbing and electric you should be able to figure it out. There are generally valves underneath (inside the cabinet) that regulate the flow and one may not be set right. Or, it could be a bad flow/sail switch. You are going to need to figure out why the overheat condition. But, there are things that can kill you inside. Don't fool around if you are unsure.
    Support the site
